Question about Garmin StreetPilot C330 GPS Receiver
I downloaded files for City Navigator 2010, but I can't figure out how to get them onto my Garmin c330 streetpilot. There is no "setup" file or any other executable. Help?
  • acmusco Jun 06, 2009
    Unfortunately there are no executables except a tuturial. Directories are IMG, Additions and Support. File is about 2.62 Gb in size. Guess if it doesn't come from the Garmin page, which won't let me download, it's not usuable?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
If the file is downloaded from the official page myGarmin, the file will be named something among the lines CNEU_2010 .. it should be an executable file which requires only to be ran, and then the installation on both your PC and GPS will start.
Posted on Jun 03, 2009
Put maps on my sd card without connecting navigator
Place map file on as card and rename it gmapsupp.Img. the map should be unlocked first. So download caefully
Jun 22, 2014 | Garmin StreetPilot C330 GPS Receiver
How do I upload Maps update for Streetpilot c330.
Installation Instructions
  1. Download the self-extracting archive file for your Streetpilot c330 onto your hard drive.
  2. Connect your Streetpilot c330 to a free USB port on your PC with the correct PC interface cable.
  3. Unzip the files in the archive by running the downloaded executable file.
  4. Follow the instructions provided by the launched update application on your computer.
Get the update here:
http://www8.garmin.com/software/StreetPilotc330_610.exe
Mar 19, 2009 | Garmin StreetPilot C330 GPS Receiver
Backup Streetpilot C330
HOW TO INSTALL CN NA 2009NT ON A STREETPILOT C330
The CN NA 2009 NT mapset is too large to be installed in the C330 without putting part of it onto an SD card. My recommendation is to use MapSource to build an image file containing the lower 49 states, PR & the USVI and upload it into the internal memory as a new 'gmapprom.img' file, and then build a new 'gmapsupp.img' file for an SD card containing Alaska & Canada.
Start the process by using MapSource to create a new 'gmapsupp.img' file, choosing the lower 49 states plus PR/USVI. Make sure that the total mapset size is no more than 975MB (930MiB) MAXIMUM. Anything that's very much larger will cause the installation to fail, due to insufficient internal memory. Note: Even though MapSource lists the mapset size in "MB", it actually measures it in "MiB". DO NOT EXCEED 930.0 MAPSET SIZE AS LISTED IN MAPSOURCE! (Can you get away with "just a little bit more"? Yes, you can, but why push it when you can simply put the rest on an SD card? Otherwise, you'll spend 40 minutes uploading it to your C330, only to have it fail at 99%. No fun... )
After selecting these maps tiles, choose 'Transfer > Send to Device...', but do NOT select your C330 as the destination for your new 'gmapsupp.img' file; instead, choose to send it to a blank 1GB (or larger) SD card plugged into one of your USB ports by way of an appropriate adapter (or to the 'C:\Garmin\' folder on your primary hard drive if you're running a specially-modified MapSource executable). MapSource will automatically create a 'Garmin' folder on your SD card and create your new 'gmapsupp.img' file within it.
Once you've successfully accomplished this task, copy the new 'gmapsupp.img' file to your hard drive's 'C:\Garmin\' folder (unless that's where you sent it in the first place, as noted above), then re-name it 'gmapprom.img'.
Next, repeat the process, selecting Alaska plus all Canadian provinces instead. Do NOT select any of the U.S. map tiles you selected the first time around. Capiche? This time, however, after creating the new 'gmapsupp.img' file on your SD card, do NOT copy it to your hard drive and do NOT re-name it. Just plug your SD card into your C330.
Finally, we're almost ready to upload the first file you created -- now called 'gmapprom.img' -- into your C330. First, we have to make sure you have a copy of Garmin's WebUpdater package installed. Open your 'C:\Garmin\' folder. Is there a 'WebUpdater' folder there? Yes? Great! Look inside and you should see a file named 'WebUpdater.exe'. If you've got it, you're almost there.
You don't have WebUpdater installed? Go get it and install it; it's a free download from Garmin. I'm using Windows XP; be sure to get the Windows version that's right for you. (To the best of my knowledge, this procedure does not work on a Mac. Sorry... ) http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Now that you've got it installed, do the following:
- Right-click on an unoccupied area of your Windows Desktop; when the menu pops up, choose 'New', then 'Text Document'.
- Double-click this document; this will open up a brand new blank document in NotePad (or whichever text editor you've chosen).
- Copy and paste the following line of text into it...
C:\Garmin\WebUpdater\WebUpdater.exe /upload_file rgn=49 path=C:\Garmin\gmapprom.img -autorun usb /i
- Select 'File > Save' then 'File > Exit'.
- Re-name the file to 'C330_Map_Update.BAT'
- With the C330 connected to the PC by USB (your drivers have already been installed previously, yes???), double-click on your new 'C330_Map_Update.BAT' file.
- Sit and watch as the WebUpdater application opens up a command-line window and copies your new 'gmapprom.img' mapset into your C330!
- It will take approximately 35-40 minutes if all goes well.
-Don't forget, you'll need to have previously entered your 25-character unlock code into MapSource. That unlock code must be specific to your C330; just because your Nuvi's unlock code allows you to create mapsets in MapSource doesn't mean that those mapsets will work in your C330!
Jan 15, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot c330, won't re& change maps.
I'm not 100% sure but we were told that there isnt' enough memory to hold all the maps in the c330 because the new maps are larger than the memory in the c330. Does it have an area to choose where you can take out Canada? If so then it has enough memory to load the maps minus Canada. Hope it helps you a bit.
Oct 13, 2008 | Garmin StreetPilot C330 GPS Receiver
I need maps from brasil
These maps are available for purchase from Garmin. Go to www.garmin.com. Click on Automotive, then the StreetPilot C330. Click on Maps, then look for
microSD/SD data card, City Navigator NT Brazil . They are charging $119.99 USD plus tax for this map.
Mar 27, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 update
What are you trying to update, firmware or maps? Firmware updates ae free from Garmin. Just go to www.garmin.com and download the WebUpdater. If you are trying to update the maps, these are available for purchase in CD or SD card formats, also from Garmin or your local retailer. They should be approx. $70.
Mar 23, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin Registration Code lost
YOU CAN USE ANYONE ELSES CODE OF SAME MODEL :)
Mar 09, 2008 | Garmin iQue 3600 GPS Receiver
POIs for Street Pilot 2610
Sometimes going to Garmin's web site can help answer questions like this. Garmin has discontinued the StreetPilot 2610, which means it has not been produced for some time. This is from the manual of the 2610/2650:
CD-ROM:
Accepts downloadable map detail from
Garmin PC-based MapSource® City
Navigator™ DVD (included), which
provides street-level detail, addresses,
listings of nearest restaurants, hotels,
ATMs and more. Note: Requires
CompactFlash® card (128 MB CF card included)2
Feb 10, 2008 | Garmin StreetPilot C330 GPS Receiver
POI menu with custom POI does not appear anywhere on the C330?
You need to use Garmin POI loader to input custom POI. After loading POI's they will show up in "My Favorite" under "Custom POI"
Jan 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
129 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
