Question about Uniden Cordless Phone
STUCK ON "DO NOT DISTURB" AND PHONE WON'T RING.
I don't know how I even got there (quite accidentally) & now I can't get out & back to regular phone usage. 2 phones of 3 are on "Do Not Disturb" & will not ring!!!!! I inadvertantly cannot find my "Manual" to look up this problem & fix it so I need help.
  • 19 Answers
SOURCE: PHONE WILL NOT RING
For GE 6.0:  There is a button on the base on the lower right corner (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz:
1. Pick up the phone handset and dial *98.
2. Press 2 to disable Do Not Disturb.
3. Once you hear the confirmation that Do Not Disturb has been disabled, you may hang up the phone handset.
Posted on Nov 13, 2008
patel352003
  • 192 Answers
SOURCE: Uniden corless phone says Do not disturb on screen
It seems problem of programming. You have to reset it. I can say that if you are enough knowledge of it's initial setup process you may tri by removing battery and again attach it with your phone. This will reset your phone on factory status. You may be loss your data stored but get working phone. Vote it how this fix your problem.
Posted on Jan 08, 2008
  • 108 Answers
SOURCE: Our phone is showing Do
You did not specify what kind of phone system you have so this is a shot in the dark, if the phone has a light on one of the other keys that is probably the DND ( Do Not Disturb ) button, so simply press the button and it will cancel the DND. If this is not the case please provide more information and I'll try to help.
Posted on Jul 28, 2008
  • 19 Answers
SOURCE: Taking off Do Not Disturb
For GE 6.0: There is a button on the base lower right corner  (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz:
Hope this helps!
SOURCE: My uniden powermax 5.8 ghz set itself to Do Not Disturb.
The do not disturb feature (DND) allows you to mute the ringer, the base, and any registered handsets at the same time. The phone must be in standby mode. Press and hold do not disturb on the base. You will hear a confirmation tone, and the DND LED illuminates. To cancel the DND feature, press do not disturb again. You can also mute the ringer tone while the phone is ringing by pressing do not disturb on the base.
Activating the DND while the answering system is off will turn the answering system on automatically. The answering system setting will reset to the original setting when you cancel the DND.
If you press answer on/off when the DND and the answering system is on, both of the DND and the answering system will turn off.
To mute the ringer tone temporarily for each handset or the base, when the phone is ringing, press the MUTE soft key on the handset or the base. The ringer tone will return to the previous setting starting with the next incoming call.
Posted on Jul 07, 2009
Why does my mobile phone not ring when someone calls me. It goes straight to message centre
You may have accidentally turned on Do Not Disturb mode. In the top right corner of the screen, is there a tiny icon that looks like a crescent moon? If it's an i-phone, go to settings, and in the second group of items, make sure that Do Not Disturb is turned off.
Jul 09, 2017 | Cell Phones
Phone says "Do not Disturb" and will not ring
If you have an iphone, you have your setting set to "do not disturb" which will silence calls automatically which is a great feature for times when you are in a meeting or even a movie theater.
I'm assuming you have an iphone which is the most common phone and easiest to accidentally turn this mode on. If so, go into your settings and underneath the "notifications" and "control center" tab, you will see "Do Not Disturb". Switch off the "manual" tab as well as "scheduled" if that setting is on. Now, your phone should ring like normal.
Hope this helped!
Mar 11, 2016 | Lands Phones
I receive texts from many people but one particular person's texts do not ring. Her contact is set on default; even if I change the tone, delete her contact and re-enter it doesn't so
You may have accidentally setup Do Not Disturb for that one person's conversation. This feature is number based and could be saved through contact deletion. Open the conversation with this person, click the i button in the top right and you should see a switch that says Do Not Disturb. Now make sure that it isn't enabled.
Here is a screenshot:
Dec 07, 2014 | Apple iPhone Cell Phones
Both phones work except they both will not ring in. If you are looking at it when a call is coming in they will light up blue but no ring sound. Ring volume is on High. What do I do to get them to ring...
I think you may have accidentally pressed the do not disturb button.It is on the base of your phone and shows red when on Just press it again.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 26, 2011 | GE 28112EE2 Cordless Phone
Program "Do not disturb" on business phone
It's pretty straightforward. You pick a spare button, dial FEAT 00 press the blank button (with a light) and press FEAT 01. There are considerations that I'll reproduce here.
Do Not Disturb (F01) 8
Use this feature to be able to press a programmed button to prevent incoming calls for the
extension from ringing (lights still flash). When Do Not Disturb is on, outside callers hear ringing
while inside callers hear a busy signal. You should use Do Not Disturb only if someone answers
outside calls for your extension when you do not answer them.
Considerations 8
Do Not Disturb is available only on system telephones.
Do Not Disturb requires a button with lights. When the Do Not Disturb feature is on, the light
is also on, indicating that the telephone will not ring.
■ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
to transfer calls to you.
■ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
the Hunt Group will skip your extension and ring immediately at the next available extension
in the group.
■ To avoid missing calls when Do Not Disturb is not needed, turn it off.
■ If Do Not Disturb is active at a doorphone alert extension, the person at the doorphone hears
signaling, but the alert extension is not signaled.
■ Unanswered calls that are transferred from an extension with Do Not Disturb active ring at
that extension if they transfer return.
■ Extensions with Do Not Disturb activated do not receive Caller ID information, unless the call
is answered.
■ Users with Automatic VMS Cover Assigned or with VMS Cover turned on can activate Do
Not Disturb
to Send All Calls immediately to their voice mailbox.
■ Users with Call Coverage turned on can activate Do Not Disturb to Send All Calls
immediately to the covering extension.
■ You cannot use Call Screening (F25) when Do Not Disturb is turned on.
Carl
May 10, 2010 | Lands Phones
AVAYA 5610SW IP Phone will not ring, only red light come on
Under the options button. There should be an "Audible alert" option...
Apr 02, 2009 | Avaya 5610 IP Phone
Stuck on do not disturb
Press the "do not disturb" button on the main base station.
Mar 26, 2009 | Thomson GE-28115FE1 Cordless Phone
My phone will not ring when called,it will just light up.
Perhaps you accidentally hit the DND (Do Not Disturb) button. Touch it again to take it out of that mode.
Jan 01, 2009 | GE 25952 Cordless Phone
GE Cordless phone "Do not Disturb" setting
There is a button on the main base that says " Do not disturb" my 4 year old son must have pushed it. It was an easy solution.
Thank you!
Jun 16, 2008 | Uniden Cordless Phone
No incoming ring
For GE 5.8 GHz:
Hope this helps!
Dec 23, 2007 | GE 28111EE2 Cordless Phone
Uniden Cordless Phone Logo
126 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
