Question about Lexmark X4650 InkJet Printer
PAPER JAM IN MY LEMAX X4650
IVE TRIED DEFAULT SETTINGS,THERES NO PAPER STUCK, THE PAPERS LINED UP FINE AND SEEMS TO BE CORRECT PAPER. CAN ANYONE HELP WITH OTHER SUGGESTIONS PLEASE
    Problem Solver:
  • 9 Answers
Have you really checked the printer, there may be a small piece of paper jamed inside the printer, this is a common fault and common fix for most printers.
Posted on Jun 03, 2009
Paper jam inside lexmark x 4650 - how to get paper out of machine
If you can't get the paper jam out from the feeder, open the cover to see where the cartridges are. See if you'll have a better hold of the paper stuck in it. Hope this helps.
Jul 26, 2010 | Lexmark X4650 InkJet Printer
Printed paper path
sure...check your print manager settings, first, to see if that exit tray is selected as default..
Mar 15, 2008 | Kyocera FS-C5030N Led Printer
Paper keeps going in and jamming on the x4650 - so it won't print. Have tried reloading, turning off machine. Seems something inside is causing it to go in crooked on one side even though I have the two...
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 07, 2010 | Office Equipment & Supplies
My epson cx3200 says paper jam, I dont see any paper jamed, when i press the button to say ive cleared it,it then runs a sheet of paper through it and says paper jam again, surely if there was a paper jam...
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 06, 2009 | HP PSC 2210 All-In-One InkJet Printer
My lexmark x4650 keeps on getting paper jams and i think its something to do with the roller so any info please help :D
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Sep 13, 2009 | Lexmark X4650 InkJet Printer
False paper jam message
Look for tiny pieces of paper shreds that might stuck up with the rollers.
Jul 30, 2009 | Lexmark X4650 InkJet Printer
Lexmark X4650 ink jet printer has paper jam
Please follow these steps to set your printer to defaults:
1. Please make sure your printer is set in Copy Mode.
2. Press the "setup" button, you will find "Maintenance" displayed.
3. Use your arrow keys to locate "Set Defaults" and press "OK".
4. Press the arrow key to find "Use Factory" and press "OK"
This process would reset your printer to Factory defaults.
Apr 28, 2009 | Lexmark X4650 InkJet Printer
Paper jam in Lexmark printer
First turn the printer off then back on:
1 Make sure:
• You use paper designed for inkjet printers.
• If you are using photo, glossy, or heavyweight matte paper, you load it with the glossy or printable side facing
you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
• The paper is not used or damaged.
• If you are using specialty paper, you follow the instructions that came with it.
• You do not force paper into the printer.
2 Before loading paper, slide the paper guides out toward the edges of the paper support.
3 Load the paper vertically in the center of the paper support, and adjust the paper guides to rest against the edges
of the paper.
Note: To avoid paper jams, make sure the paper does not buckle when you adjust the paper guides.
Apr 12, 2009 | Lexmark X4650 InkJet Printer
Wont print
I'll have to begin with the obvious...
Have you set the printer preferences correctly for contact sheets?
Check all of your default printer settings in control panel>printers & faxes> your printer>right click>preferences
If these are not correct for what you are printing you need to set up your printer for what you are printing at the time.
(You may know all this already)
I would also do a left click on the printer icon and cancel all documents if there are any in line.
I would then turn off the printer, open the paper jam door and give the paper roller a gentle push upward until it clicks. close the paper Jam door.
Unplug the printer.
Wait about 15 minutes. plug it back in and turn it on and give it a new try ( remember to do the setup for whatever you are printing)
Good luck. Let me know if this works!
Aug 16, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Lexmark X4650 InkJet Printer Logo
347 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
