Question about Kenmore 98702 Stacked Washer/Dryer
Washer leaking water, flooded my apt. this is a kenmore stackable. how can i fix it?
  • DANIEL MORRETT Jun 03, 2009
    I FIXED THE PROBLEM, DRAIN HOSE CAME OFF. I FOUND SOME COINS IN THE HOSE. IT MUST HAVE BLOCKED IT AND PRESURE BUILT UP.EASY FIX. THANKS
I know it needs a new pump, but I can't find the model number of the unit anywhere.
Posted on Jul 21, 2009
My kenmore elite quiet pak9 washer is flooding on the inside with water. I used a bucket to empty the washer but the next morning, it started filling up again. what do i do?
I just had mine fixed. It was a small hole in a water line inside the machine. Mine only leaked heavily when under pressure.
Feb 17, 2015 | Kenmore Washing Machines
Why is water automatically draining as it is filling?
There is most likely a leak with water getting into the cabinet of the washer activating the anti flood switch which in turn drains all water out to stop flooding check for damaged door boot
Dec 21, 2014 | Kenmore Washing Machines
Mom has a Kenmore stackable washer. She ran water into the washer and all the water came out on the floor.
This seems like a difficult problem but is an easy fix. Remove the hose from the water level switch and blow out the sediment like this:
Service manual and more photos HERE
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
My kenmore oasis washer has started leaking out water and flooding my floor. have you had any other complaints about this problem and how to fix it.
first of, you need to find out where the water is originating from, pull washer away from wall and look for water dripping. usually water leakage starts from pump. on this washer there is a circulation pump and a drain pump on bottom left and right side. check all hoses and enure that there is no pin holes started
Aug 12, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore stackable washer wont work on Cold cycle only hot water
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 07, 2010 | Kenmore 98702 Stacked Washer/Dryer
Stackable softener dispenser stays filled with
if its the dispensor on top of the adjitator it snaps off then you can unscrew some of them to clean. or just soak it in hot water.good luck!
Jan 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
How can I fix my Kenmore portable washer 100.49722990?
Most common cause for water leak
is around the water level sensor connection, a small hose from the tank bottom rear, to the control panel, if loose or removed it is a small constant leak. if loose snip 1/8 inch off the hose refit and pull a zip tie around it tight
if it were the drain hose or pump, it would usually be a very large leak that increases when the pump is running and floods the laundry
Jun 21, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
My washing machine keeps leaking from the bottom
For me there is not enough information. What hose did you replace and when does the machine start to leak ?
Dec 26, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
292 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
