All gauges light up with not start. The problem started a few days ago with a slow clicking before starting. It did not happen every time. Now nothing. Checked the battery. Cleaned all post. Wired around the aftermarket theft plug. Pulling fender to start towards starter. Any other options?
Solenoid on starter needs to be replaced. faulty thats where the clicking noise came from..
This is common on 2007 & 2008 automatics.
The brake pedal interlock does. It always release when you put it into Park/Shutdown/ Get out.
If you put it into Nuetral it should start right up.
I often just jiggle the automatic shifter firmly, and it will start right up.
The problem was located at the solenoid. The wire that slides over a post had worked itself loose or was never installed proper. Pushed wire back onto post and engine started.
