Question about HP OfficeJet 7410 All-In-One InkJet Printer
My HP 7410 tells me that no cartridge is installed despite a tight fit and new cartridge. Please help!
    President:
  • 1,185 Answers
If the cartridge is a new HP one and it is fitted with the usual chip on the front you have either a duff cartridge or you have damaged the chip while installing it.
If it is a re-filled cartridge then the HP software will try to kick it out and you will either have to disable the ink level detector bit of the HP software or try a different supplier for your cartridge
Posted on Jun 03, 2009
I just refilled a 97 tri color cartridge for my HP 7410. It wont detect the new refilled cartridge. We have tried the #3 and #6....no results. please help.
The only thing you can try now is
# and 9
Thoguh this will lead to losing all the numbers saved and IP address if you have in your printer
Feb 26, 2011 | HP OfficeJet 7410 All-In-One InkJet...
Trying to reprogram HP7310 to accept cartridges which are numbered differently in New Zealand than in UK where we bought the printer. NZ cartridges fit but printer (correctly) identifies the cartridge...
Not really a solution but.....spent hours on the phone to HP helpdesk & then they were also having to explain how we could log in to help website. Eventually we managed to get the issue sorted (the cartridges work & printer isn't giving us an error message) but still not quite sure how - just had to follow endless instructions (lots didn't work). Probably was a case of patience & getting through to someone who could actually help with the problem. So all OK - until next time the cartridges need changing! Thanks anyway.
Oct 08, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet 7410xi All in One - annoying cartridge notifications
you must calibrate your printer when installing new cartridges
Jul 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 printer displays error ''remove and check colour cartridge
I think that spring must have gotten loose that holds the cartridge in place, right hand side, put it back where it belongs, might want to compare with the other, black cartridge side.  Good Luck!
May 13, 2009 | HP OfficeJet 7410 All-In-One InkJet...
I have a HP 7410, every time I print I get three error messages. First one is "New HP Photo Print Cartridge successfully installed". Second one is "New HP Tricolor Photo Print Cartridge successfully...
Perform a semi-full reset on the all-in-one by following the steps below
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find the hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
8 Allow the all-in-one to re-initialize. This may take a minute or two.
9 If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information.
Let me know if this helps.
If it doesn't, I will research it further. If it does please rate it.
Joe
Nov 17, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Printer does not recognize color cartridge for my HP OfficeJet 7410
Are you sure it's a genuine HP cartridge? Sometimes remanufactured cartridges aren't recognized by the printers. HP and others make them so that they have a chip inside that ensures only new genuine cartridges can be used. Try a new HP and see if that solves the problem. If you've already tried that one, then make sure the contacts in the printer are clean. If you still have a problem, then I'd say try a new printer!
Oct 19, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Circuit board
HP has extended the warranty for some of these printers like the 7410. I'm not sure about the 7310. But it's worth giving them a call.
Have your serial number ready when you call HP. (800) 474-6836
Tell them you have a broken carriage shute and print cartridge rejection.
Hope that helps.
Apr 30, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Keep getting popup windows (3) every time I print - EVERY TIME!
You may need to run the Print Head Alignment once to make it happy.
Hope that helps...
Geno
Apr 04, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Ink cartridge carriage HP 7410
i would trace the line back and put a small wire to replace the broken path.
Jan 13, 2008 | HP OfficeJet 7410 All-In-One InkJet...
INK LEAKAGE
Dear sir. A simple fix:Put a piece of scotch tape around it tightly until you get it installed.A lot of new ones come this way.
Dec 29, 2007 | HP LaserJet 1500L Color Printer
HP OfficeJet 7410 All-In-One InkJet Printer Logo
90 people viewed this question
Seeker5211
Seeker5211
