Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Convergence The colors won't converge with the remote. The picture is semi viewable however top and bottom of screen colors do not come together. An individual has suggested that my picture tube may be going, Will replacing the 3 tubes rectify the problem?. The TV is 4 years old. I also need to have those color tubes identified within the areas of the TV
  • Dadof6 Nov 09, 2007
    Our tv recently began displaying a grainy, horizontally lined picture with ghost images of and blue, sometimes with a large symetrical arc of blue. The on-screen convergence with the remote did nothing to rectify the problem. At times, turning the tv on and off will succeed in clearing the picture up temporarily, but the problem returns randomly. The problem is consistent on all satellite channels, and with dvd's. Convergence problem?
    Genius:
  • 1,694 Answers
Color tubes are OK. Do not adjust. The issue at hand is called
convergence alignment.The repair involves-------
1)Pull chassis
2)Replace convergence IC's
3)Recheck alignment
work should be done by a skilled technician........T.
Posted on Oct 24, 2007
  • Vista Electronics Oct 24, 2007
    PS. Cost usually about 400.00.......T.
I have a convergence problem in the bottom of the lower left quadrant pf the screen. It is like a parabolic semi circle that is at the very bottom edge of the screen. The front screen isn't damaged at...
Tv 100% have a convergence problems,if any parts of the tv picture colors lines R,G,B are mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board the 2 STK ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 23, 2010 | Panasonic PT-47WX49 47" Rear Projection...
3-d looking picture on top and bottom of screen
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 25, 2009 | Philips 51PW9363 51" Rear Projection...
I just received a Hitachi 50" projection Tv from a friend. He was the original owner and it appears after 8 years the picture quality went bad. After spending some time with the operating manual it appears...
  • Screen looks 3D
Apr 23, 2009 | Hitachi 50GX49B 50" Rear Projection...
Picture bows in at top,bottom and sides.
  • Screen looks 3D
Apr 07, 2009 | Televison & Video
My JVC model number AV-56WP30 has a flashing convergence screen
Your TV most likely has a Convergence Chip Failure but I have not seen that symptom before.
  • Screen looks 3D
Feb 28, 2009 | Sony KP-51HW40 51" Rear Projection...
60" TV has an arc in the pic
Check the fuses 1007 & 1405. If they are blown in will cause an Arc.
Note: If the screen shrinks/expands you may need a chip kit from www.repairkits.com
Aug 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
I have a double picture on screen i could hear my TV but the color are off too with Sony RM-Y908 Remote Control? which is broke
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Oct 29, 2007 | Sony KP-57WS500 57" Rear Projection...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Convergence and picture problems
This TV probably uses two convergence IC Packs that will need to be replaced and be re-converged. There may also be a resistor or two that may need replacing as well. The projection tubes should last another 3 years or so.
Dec 26, 2006 | Apex Digital GB43HD09 43" Rear Projection...
Picture off on screen vertically-Black at top of screen and pic below bottom of screen
  • Screen looks 3D
Oct 04, 2006 | Panasonic PT-47WX51 47" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
314 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
