Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Power light blinks red 3 times and it won't power on. Replaced lamp. What do I do now?
  • 10,594 Answers
Recheck Lamp cover and fix / place it properly. 3 times red blink shows lamp cover is not seated well.
Posted on Jun 03, 2009
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
I have a 4 year old Sony KDF-E42A10 television - the power/standby light blinks red 5 times, pauses, blinks red 5 times again, etc. I have replaced the lamp previously when the light was blinking red 3...
5 blinks means there is a problem with the video board. It could be as simple as unplugging everything, includding power. Wait 3 minutes then plug power only back in. Or it may be a damaged component that requires replacing.
Hope this helps
TV_Doctors
Jan 05, 2011 | Sony Televison & Video
I have replaced the lamp block and now the power stand by red light is going on and of (this was a new lamp block). Do I need to reset some how?
If standby red light is blinking 3 times after three second pause then check lamp cover that has no been fixed in its place correctly, it is first thing that you removed from tv cabinet to replace lamp, make sure lamp cover is back in place properly and tight.
If standby red light is blinking more or less then 3 times, let me know to diagnose problem.
Thanks.
Sep 04, 2010 | Sony KDF-E42A10 42 in. LCD Television
Just replaced lamp. when plugged in, power light
hello make sure the lamp is fitted securely and the lamp cover aswell
regards
shaun
Jan 16, 2010 | Panasonic PT-50LC13 50" Rear Projection...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
I have SONY KDF-50E2000 about 15 months old with expired warranty. One day it just refused to turn on. I have green power light for couple seconds, after that it starts blinking red 3 times with interval....
Its definately the error for lamp cover or lamp position error either the lamp door switch is broken or the lamp contacts are not making contact
Jan 08, 2009 | Televison & Video
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
324 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
