Question about Garmin StreetPilot i3 GPS Receiver
Installing usb drivers
I have put the disk in and followed all instructions up to the point where it says ready to install. when i connect the gps to the computer and click next it is still telling me to turn the power on please help thx
  • 174 Answers
Re: installing usb drivers
Go to the following Garmin website and scroll down to find USB drivers. Download the driver to your computer. Install the USB drivers.
Posted on Jan 04, 2008
0 characters
3 Points
I need to update my nav cam 7700
In the box that came with your Nav-Cam you should find a software disk and a USB cable. Install the software on your computer and when prompted connect your Nav-Cam. Follow the on-screen instructions to update the software.
May 08, 2011 | Evesham Nav-Cam 7700 GPS Receiver
I need to downlaod the 3220 maetro gps
Maps are done at least once a year. You do not have to update the maps but you have firmware updates you must at some point update. there is a disk that comes with the unit when new. Install the disk - this installs the drivers or language your pc needs to talk with your Maestro. Once your driver program is installed plug the USB cord in that came with the unit. Once everything is hooked up you need to go to the Magellan website - download the updates and install them Then and only then will the message stop. 1d80823.gif
May 08, 2010 | Magellan Maestro 3220 Car GPS Receiver
I cannot connect my magellan triton 300 to my computer, it always say "usb device not recognize
It sounds like you do not have the drivers install for your Triton, to install the drivers you will need to install the Vantage Point software that can with your unit or you can download the newest version of Vantage Point from the following link;
I hope this helps!
Nov 06, 2009 | Magellan Triton 300 Handheld GPS Receiver
Garmin gps
Install the drivers before you plug in the GPS. Then follow the directions both in the setup and on the website. There may be other things that you need to update before things will work right.
Jan 05, 2009 | Garmin StreetPilot c510 Deluxe GPS...
Garmin gps
download the usb driver from the website. Then go to your device manager (rightclick "my computer" and click on properties. then click on device manager) Once there, see if there is a yellow exclamation point next to the garmin slot. If there is, right click it and choose update driver. Then follow the prompts to locate the new driver. This shou;d solve the problem.
Apr 09, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin gps
Go to garmin website and download the latest USB drivers. After installing the latest USB drivers reboot the computer. Now attach the Garmin to the computer using USB cable. You should see Found new Hardware on your computer.
Dec 31, 2007 | Garmin StreetPilot c340 GPS Receiver
Garminc330 GPS
These would be the drivers that allow your computer to interact with your gps unit. If you use it as a standalone unit, then you won't need them. If you plan on saving waypoints and tracks or prerouting yourself and then loading it to your gps, then you will need to install the usb drivers from your installation disk, or from the garmin site before connecting your gps to the usb cable from your computer. Once loaded, you should be able to communicate with your unit and up/down load information.
Nov 29, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin gps
If you are running the USB Drivers that came with your device, it might create a problem. Get the newer updated drivers from HERE and install it. It should resolve the problem now
Nov 11, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot i3 GPS Receiver Logo
775 people viewed this question
Top Garmin GPS Devices Experts
Tom Chichester
Jonathon summesfield
Bill Gilhooly
Bill Gilhooly
Are you a Garmin GPS Device Expert? Answer questions, earn points and help others
