Question about Canon PowerShot SD600 Digital Camera
Sd600 poweshot can it take a 4gb or 8gb memory card? i was planning to buy duracell SDHC 4GB card with 10MB /sec transfer speed
  • Canon Master
  • 4,738 Answers
No, unfortunately the SD600 was designed before SDHC format cards were introduced. The max card size that you should buy for your camera is 2GB standard SD. If you look around very hard, and if you're very lucky, you may still be able to find a 4GB standard SD card. But these are rare these day (everyone has gone to SDHC at that size card), and it will be at premium price.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=ModelTechSpecsTabAct&fcategoryid=323&modelid=12913
Posted on Jun 04, 2009
I have a Pentax Kx and recently bought an 8Gb memory card. However I get a lot of blank images with the error message 'image cannot be displayed' especially if I use the continuous shooting mode....
Dear,
First of all you need to confirm that what kind of memory card your are using. The officially recommended type and brands are here
Toshiba *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
Panasonic *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
SanDisk *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
rather than these might be problematic or not compatible...
Check this first
Best of luck!
Jul 10, 2011 | Pentax Cameras
Is a SDHC Memory Card 4GB compatible with my Canon Powershot SD600 camera?
Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
Aug 26, 2010 | SanDisk 4GB Secure Digital High Capacity...
Can I use a 4GB SDHC memory card in my samsung sl310w camera?
Here is what the Samsung websites says:
MMCplus(up to 2GB guaranteed 4bit 20MHz);
SD (up to 4GB guaranteed);
SDHC (up to 8GB guaranteed);
So it is OK to use a 4GB SDHC memory card in your samsung sl310w.
Hope this helps.
Feb 25, 2010 | Samsung SL310W Digital Camera
It doesn't read 8gb sd cards on internal sd drive
There are two types of SD cards. The first, standard type, had a capacity limit of 4GB. But quite soon the technology advanced and higher capacity Flash memory has been developed, so the standard had to be revised - and SDHC was born (HC stands for High Capacity), which includes cards having 4GB and above.
There is an overlap, as you can see, because there are 4GB CD cards, and 4GB SDHC cards on the market.
Now your DELL is an older machine, and it's card reader is not compatible with the new SDHC standard. And it will not be, even with a BIOS update.
You have two options: find a 4GB SD card (they are hard to find, majority will be SDHC) and stick with this capacity, or purchase an USB SD/SDHC card reader, which is cheap, and use it to transfer files to/from your 8GB card.
Nov 22, 2009 | Dell Latitude D430 Notebook
I have loaded a new memory stick and get a message "memory card error" I have since tried another card and get the same maessage. Any idea waht the issue is.
Well if your camera is an SD600, I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Nov 17, 2009 | Canon PowerShot SD600 Digital Camera
What size of memory card and brand should I get for my new Rokinon E-Touch DZ1000
This camera has SDHC card expandable. With a minimum capacity of 4GB. So that means you can buy 4GB, 8GB ... whatever you budget.
Oct 03, 2009 | Rokinon DC59 Digital Camera
Cannot install 4GB card into TL220. Do I have the
According to Samsung's page on this camera, the following memory can be used:
External Memory(Optional) : Micro SD (up to 4GB)
Micro SDHC (up to 8GB)
4 GB is acceptable, but I think you do not have the correct type of card. You should be using a Micro SD or "Micro Secure Digital" (up to 4GB capacity) or a Micro SDHC or "Micro Secure Digital High Capacity" (up to 8 GB capacity) card. This is very different from an SD or SDHC card. These Micro cards are very small (smaller than your thumbnail) and are often packaged with an SD adapter card. Regardless if sold with or with out the adapter, the package should say Micro SD or Micro SDHC on it somewhere.
Oct 02, 2009 | Samsung Cameras
Memory card error for 4GB SDHC card on HP Photosmart printer 2710
Well SD max is 2gb, so you can get 2gb if you want.
SDHC max is 32gb. If you are not on a budget, try upgrading your printer to a newer model.
SDHC is coming out with even newer models, now with a class 10 (10mb read/write speed - but very costly).
However, if it doesn't matter to you, might as well just stick with the same printer, since SD cards are coming down in price. Just make sure you get 2gb cards with a good class speed.
Sep 10, 2009 | HP Photosmart 2710 All-In-One InkJet...
My canon sd600 is not reading PNY sdhc memory card. msg says card is locked. it's clearly not locked
HC or High Capacity is not compatible with this camera. You have to buy a memory card which says only "SD" and NOT "SDHC". Cards of 2Gb and less are usually "SD". Cards of 8Gb and more are always "SDHC" for technical reasons. Cards of 4Gb can be either, but the SDHC kind are much more common, because they're cheaper and newer.
Jun 22, 2009 | Canon PowerShot SD600 Digital Camera
I want to upgrade the memory card of my Canon PowerShot A570is. What memory card should I buy? The last that I had was a SanDisk 1.0 GB.
The camera supports SDHC memory cards, so any SDHC card should work.  If you shoot video the cards with the faster write speeds are better.  The SanDisk 4GB or 8GB cards should work well.
Apr 26, 2009 | Canon Cameras
Canon PowerShot SD600 Digital Camera Logo
817 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
