Question about JBL Marine Audio Wired Remote
JBL marine radio MR-17, remote stations not working properly
Boat is a 2006 Chaparral, replaced radio with same brand (JBL MR-17)in 2008. One remote station buttons work, but led screen is not readable(scrambled figures on screen); the other remote does not work at all. I believe the heat has effected the units???? but not sure. What is the best fix, replace or can they be reset in some fashion!
Tom W.
Benimur
  • 6966 Answers
SOURCE: jbl marine mr-17 all funtions are frozen
Initially, have you tried a full hard reset? The reset button is at the panel at the back of the faceplate, bottom left side. Of course doing so will also erase all presets and user settings & configurations.
Additionally, pls verify that the multiple contacts pins are clean, free of corrosion and makes a positive contact with its mate at the rear of the faceplate. If the unit is used in a salty environment, it may be necessary to manually scrape of whatever blue green build up develops between the connector pins and the plastic insulator. You can try using an old toothbrush and WD40.
Further to check are:
1. the red, yellow and black wire are tightly connected where they are supposed to be connected. If the unit is used onboard, it might be to your advantage to likewise check the grounding system;
2. one of the rear connector is for a remote, pls likewise check that none of the pins are shorting and no presence of any corrosion.
If problem persists, it may be necessary to seek the services of a qualified professional as this involves opening the unit up and tracing the circuitry of the logic/controller circuit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 04, 2008
hemantraj
  • 638 Answers
SOURCE: I have a JBL MR-17
check the antenna its connection and also try replace the antenna .its only because of antenna.
Posted on Jul 01, 2008
finish line
  • 207 Answers
SOURCE: I have a JBL MR-31 Marine AM/FM/CD/Sirius Ready
yes i am a repair shop and i have had nothing but problems out of those units you might want to look into a different unit boss marine is a good choice
Posted on Jun 27, 2009
MarineTech1
  • 76 Answers
SOURCE: I am trying to find
You will find the maual you need by using the following link :
http://www.prospecelectronics.com/JBL%20MR6%20manual.pdf
Posted on Sep 13, 2009
SOURCE: Jbl Marine Audio Wired Remote - my screen is
Will a REM 25 remote work with the MR 15 JBL radio?
Posted on Nov 03, 2009
I have a jbl mr-145 in a hot tub. It keeps powering on and off???
I have the same model stereo in a brand new hot tub that was having the same issue. To fix it all u need to do is pull the front cover off to access the pump controls and in there you will find a black box where a power cable runs yo the stereo. There are two screws that open a little door in the black box. In there you will need a small flat head screwdriver to move a redswit over to the 110 volts position. Turn the radio on and it should work. That black box just controls the power to the stereo.
Oct 09, 2010 | JBL Marine Audio Wired Remote
JBL MR-17.2 not recognizing Sirius satellite receiver.
I have the exact same issue. I have swapped with two identical MR17.2 radios and swapped out the sirius receiver. No change. I even bought a remote thinking I had to have a remote installed to get it to work...still no diff. Have you ever found a solution?
Jul 13, 2009 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
Jbl marine mr-17 all funtions are frozen
May 04, 2008 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
JBL Marine Audio Wired Remote Logo
395 people viewed this question
Top JBL Boating Experts
drshaddock
drshaddock
Level 1 Expert
DocZachary
DocZachary
JonSnell Electronic
JonSnell Electronic
Are you a JBL Boating Expert? Answer questions, earn points and help others
