Question about Dell Dimension 2400 PC Desktop
I added memory to my Dell Precision 4700. It beeps about 5 times and then does nothing. The memory type is correct, took all the ESD precautions, everything is pushed all the way in place and it still is not reading it. I started with (4) 512mb sticks and upped to (3) 1gb sticks. Please help.
  • 2 more comments
  • tommydib Nov 22, 2009
    can i use the memory i purchased for my dell 4700 on my dell 2400
  • Binesh Ellupurayil Balachandran
    check whether all the memory modules are of same type
  • Samuel Jayakumar May 11, 2010
    Could you please tell me the type of BIOS on the motherboard
  • Zach
    Zach May 11, 2010
    is the computer turning on or is it just beeping and doing nothing?
  • 54 Answers
Maybe: 1. One or all of the chips are bad - it happens try one at a time to find the culprit. 2. Make sure you started in the first slot 3. You have the wrong type of memory
Posted on Jun 04, 2009
6 beeps
Beep codes are generally grouped together with slight pauses between groups. I would open the cover and make sure that all the connectors are on tight and that the memory hasn't been jarred lose. After rebooting the pc, I would listen carefully to the beeps and find the grouping codes. I am posting the link to the dell support site with the code grouping explanations.
Dec 17, 2011 | Dell Dimension 4700 PC Desktop
Not reading memory cards. No screen at all
It might a month board issue then. If its not under warranty, try to disassemble the mother board and assemble it back. Note down each connectors you are removing if you are not expert. If you have isopropyl alcohol, clean the memory slots, watch if the clips are not broken. If nothing resolves, it will be the motherboard issue
Mar 02, 2010 | Dell Dimension 4700 PC Desktop
Dell GX150 beeps 5 times on startup.
This normally means there is a memory error. Have you recently added memory to the sytem? You can try to remove and reseat all memory modules in the system to see if that clears the problem.
Jul 10, 2009 | Dell Optiplex GX280 (99301) Motherboard
I have a dell Dimension 8250 and replaced the memory cards with a higher memory. I got a memory error beep code so I replaced the original. I'm still getting the beep code. Any ideas? I was careful...
Please check the following link for complete information on Dimension 8250
http://support.dell.com/support/edocs/systems/dim8250/
Check the technical specification section to see if u bought the correct memory type for this computer to upgrade..if yes then proceed to the adding and replacing parts section to check for the instructions on adding memory.
Jun 27, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Beeps, wont boot up
Most of the time when it beeps, and there is nothing show on the computer screen, it is a RAM problem. A stick of ram may have gone bad. If you have two sticks of ram in the computer, you can try to remove one stick at a time to see which one might have gone bad.
Mar 23, 2009 | Dell Dimension 4700 PC Desktop
Four beeps wont turn on, Dell 4700
The four beeps usually indicate a memory problem and it won't pass it's Power On Self Test. Try reseating the memory sticks, or, if you have two of them, take one out and try to start the machine and then swap them.
If this doesn't solve the problem, you most likely have a bad motherboard.
Feb 01, 2009 | Dell Dimension 4700 PC Desktop
I have two dell computers, dell dimension 4600, and dell optiplex gx270 smf. I've checked into upgrading the memory on the gx270. It says that it uses the same memory configuration as the dimension 4600....
even though the memory stick sizes are the same, and the speed, there are other differences between memory types, such as parity/non parity, 2x32, 16x4 etc. more than likely, the speed of the memory sticks are different. the easiest fix for this is put the slower memory sticks in bank0 and bank1 (logical numbering used) and then the faster memory sticks in bank3 and bank4. this will cause the faster memory sticks to run at the speed of the slower memory sticks. If your sticks are parity and non-parity mix, then you will probably not be able to combine them.
Sep 26, 2008 | Computers & Internet
Added a memory stick to my Dell 2400 Desktop computer and the monitor, mouse, & keyboard won't work
Hi
The supported Memory types for Dimension 2400 Series is PC2100 (266-MHz) or PC2700 (333-MHz) DDR SDRAM (non-ECC). Supported Memory capacities are 128, 256, or 512MB and a Max if 1GB (1024MB).
The first obvious question is does the new 512MB Memory module meet the above specification? Some Memory modules are able to steep down speed.
If it does, then first ensure the new memory module is properly installed. Take ESD (ElectroStatic Discharge) precautions or you may damage the new memory module and/or the system board.
To proceed compare the system beeps and diagnostics lights color and sequence to the Advanced Troubleshooting guide.
It is possible that the new memory is DOA (Dead On Arrival). Or there is a new fault on the system. If you have access to another compatible system, you may test the new and old memory modules. You may also swap the new and old memory modules to determine if the memory slot is at fault.
Lastly, if you remove the new memory module, does the system complete POST (Power On Self Test)?. If it does you may indeed have a DOA or incompatible part.
Mike
Jul 26, 2008 | Dell Dimension 2400 PC Desktop
Beep problem Dell Dimension 4700
Beep problem update - Dell 4700. Last night started computer - cold boot. The screen had just started to light up and then went black and computer started beeping in an interrupted sequence. Fan speed increased considerably (suggesting overheat?) Shut it down and attempted two restarts with no success. This morning I unplugged all cords, opened case, pulled and reset memory cards and vacuumed inside. The computer was very clean so really don't suspect that dust was an issue. Buttoned it back up plugged in plugs and restart successfully accomplished. Have no clue why. Some square electrons, I guess.
Dec 19, 2007 | Dell Dimension 4700 PC Desktop
Dell Dimension 2400 PC Desktop Logo
167 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
