Question about Frigidaire PLMV169DC Microwave Oven
Plmv169dc not heat and the extractor fan don't
Plmv169dc not heat and the extractor fan don't work evrything else work .it is only one and 1/2 years old
  • Frigidaire Master
  • 9,047 Answers
You probably have a bad primary interlock (lower door switch) or its mount is loose or broken.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Posted on Jun 04, 2009
Will work, but, does not heat up anything
When you press the "Start" pad to begin cooking, do the inside light, cooling fan, and turntable ALL come on?
If not, which do and don't?
Is the oven louder or quieter than usual?
Dec 12, 2011 | Frigidaire PLMV169DC Microwave Oven
How do you get the fan off?? It just came on by iyself
I THINK THE RELAY IS STICKING .
CHECK THE FAN RELAY.
THANKS
PLEASE RATE MY WORK
Sep 11, 2011 | Frigidaire PLMV169DC Microwave Oven
I started up oven and it made two popping sounds. now fan lights turntable still work but not heating also sounds different then before.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 30, 2011 | Frigidaire PLMV169DC Microwave Oven
It runs but no heat
common probelm with microwaves if everything is working on unit with the exception of the heat itself... then it is very possible the magnetron or the thermal fuse to the magnetron has failed... usually yoiu can access this behind the control panel/control board assembly and test with a volt meter ... the magnetron is what does the heating and is common failure based on your description of problem.... if it is magnetron then the cost is sometimes high to have replaced and will have to be weighed into option of replacement.... most magnetrons have a 3-5 year warranty so it may be beneficial to have a servicer look at it if still under warranty and you may only be out labor cost
good luck to you .....
Jan 20, 2011 | Frigidaire PLMV169DC Microwave Oven
Less than 5 years old - Microwave Panel lights up, turntable turns, fan works - everything works except it doesn't heat food. Heard a pop, and now it runs louder than before but doesn't heat. Any ideas?
That pop was the magnetron frying. This is a repairable problem, but feirly expensive, around $300 if you have it done by a professional.
Please rate my response if it was helpful to you.
Thanks, Repairman45.
Dec 02, 2010 | Frigidaire PLMV169DC Microwave Oven
Stop heating
heatman101
Jun 24, 2010 | Frigidaire PLMV169DC Microwave Oven
Frigidaire Microwave Fan won't shut off plmv169dcd
Had the same issue, leave Microwave unplugged for 30 minutes and then plug back in. My fax stopped blowing and now fucntions 100% normal again HI/LO / OFF
Best of Luck!!! :)
Jan 17, 2010 | Frigidaire PLMV169DC Microwave Oven
Microwave stopped heating up the food. Everything works except for the heating mechanism.
Check the door safety interlock switches. Remove the cover to find these small micro switches on the side away from the hinges.
Need more help ... post a comment here
thanks for using FixYa.com
Nov 02, 2009 | Frigidaire PLMV169DC Microwave Oven
No heat from microwave oven
How old is your oven?? If more than 2 years, it may have a bad magnetron tube or other high voltage components. You will need to have it checked by a qualified technician to get an accurate repair estimate that includes everything it needs.
Jan 26, 2008 | Frigidaire PLMV169DC Microwave Oven
Unusually loud
kaic...I am not sure what is loud...fan, humming??? Are you making popcorn? Very large or small item? Does a dish get very hot?? That will do it.
Dec 18, 2007 | Frigidaire PLMV169DC Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
334 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
