Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
There are 3 fuel lines in my Ryobi trimmer...need
There are 3 fuel lines in my Ryobi weed trimmer...need scamatics as to where each one goes in and out of... one sprung a leak and I cannot find where it came from...thank you
SOURCE: ryobi rlt30ces trimmer
Hi there, takes a bit of working out without a manual, but try this....take bottom half of trimmer line spool off, get piece of spool line approx 60 cm, long and thread through centre holes, ( bit fiddly but ) pull line through until you have equal length on both sides, dont try and wind it up onto the spool, just put ends of line through outside cover holes, then lock spool in place in other half. now simply wind the knob at the end and the line should retract into the spool., sounds complicated but really isnt, best regards and good luck, Philbee
Posted on Feb 28, 2009
  • 297 Answers
SOURCE: I REPLACE THE FUEL LINES,NOW IT ACTS LIKE IT WANT TO START,BUT D'
http://outdoordistributors.com/pdf/Ryobi/RYOBI-700r-serials-304051232-thru-.pdf
Have a look at this drawing.
Posted on Apr 18, 2009
  • 8 Answers
SOURCE: ryobi 700r gas trimmer, replace old fuel lines
Line from tank with the filter on it is the supply line and goes to the carb inlet fitting. This is typically on the "bottom" of the carb (with the tank being up) and will usually have a fitting with barbs or a bulge on it to ensure a tight fit. The other fitting on the carb is the return line and is usually a straight tube fitting with no barbs. That line goes the suction side of the primer bulb. The third line goes from the outlet of the primer bulb to the return barb fitting in the bottom of the tank. Fittings have to be removed from tank to properly install the new hoses on them. Remove retainer ring on outide of tank and push fittings into tank, then shake out of the fill opening. More details on replacing hoses are listed in another post about Repairing Ryobi trimmer.
To leemineres, if hoses are on right and unit still stalls after starting initially you probably need to disassemble carb and clean out using spray carb cleaner. May be sticky needle valve, or partially plugged port or jet.Could also be hole in diaphragm. Gasket and diaphragm kit would be good to add when you take apart, even if diaphragm does not have a hole.
Posted on May 20, 2009
  • 148 Answers
SOURCE: Installing new string line for Ryobi 4 cycle straight shaft s430
Go to www.managemyhome.com and download a free copy of the onwers manual.
Posted on Jul 14, 2009
SOURCE: How do you get the fuel line connected to the fuel
You must run the fuel line through the back of the tank and out the filler hole,make your connections,i used a small amount of vaseline to make the connections.Then pull the filter into place,make sure some of the nipple of the filter pokes through,then slide the retainer ring on the hose and force it onto the filter nipple.
Posted on May 15, 2010
Ss30 ryobi weed eater fuel ratio
I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
Fuel line for ryobi
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up aginst tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulbgoes to top port of carburetor. that is the way thay go on.it is important to make sure you have the same fuel line I.D.3/32 and O.D.3/16 are very important! also if old line dissolved it will get in carb. and clog ports & small screen inside.clean inside of carb. with carb. cleaner & air pressure. to get your parts and numbers ,go to mtdparts.arinet.com, parts,791-683398,fuel line assembly,this is for most fuel line trimmers~~~hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you. ``
Feb 12, 2012 | Garden
I have a 26cc ryobi weed trimmer--primer bulb will not draw fuel, but will draw fuel when I loosen the 2 screws that hold down the bulb
Possible issues:
1. Primer bulb or bottom assembly has crack or hole in it (needs replacing). See ebay for about $6.00
2. Fuel lines are not sealing to the primer nipples properly (cut line and re-attach if you have sufficient line available) otherwise; replace.
3. You may be somehow kinking the fuel lines when you clip it back in place due to fuel lines too short
My bet: #1 or #2. Good luck!
Sep 17, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a ryobi lawn Hornet (weed trimmer) MKIII, i...
Sounds like it has a fuel blockage. Three things to check are;Inspect the fuel-filter (inside the tank) for contaminants. Inspect fuel lines for cracks. Inspect carby for oil residue (blocking the jet). Hope this helps
May 17, 2010 | Garden
Need a diagram that will show the tubing feeds on ryobi weed trim
If you need a fuel line diagram for ryobi 775r let me have your email address.
tony
Oct 13, 2009 | Garden
I have a ryoby 31cc weed eater I need a diagrm on the corect posision of fuel lines
Typical fuel line routing2.gif is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Sep 25, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
442 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
