Okidata C7500 Little part broke on the duplex tray. Won't Duplex
A little part broke on the Okidata C7500 duplex tray. Won't duplex. What to do? Live on a farm in the country - No local dealers. can I just send the tray somewhere. Okidata is too big to be able to help.
Big fancy machine just sitting waiting for a miracle. Justin
  • 54 Answers
You will probably save money by purchasing a new duplexing unit online.
Posted on Jun 03, 2009
Duplex feed not working
Check the C6200 Device Settings in the properties and make sure that the Duplex Unit is installed.
original?v=mpbl-1&px=-1
Dec 09, 2013 | Brother HL 5250DN Laser Printer
Duplexer problem
There are several thing which may cause unexpected jams in the duplex tray...,
1. first thing to do is eliminate all other possibilities by removing the netCard/Net connection Parralel connection so the machine is Stand Alone. make sure there is paper in the feed cassette 2 ( paper Tray)
press the TICK to enter menu
scroll down to diagnostic- press TICK
scroll down to paper path test - press Tick
scroll down to Source and select tray 2
scroll down to Duplex And select YES
( if the duplex option is not visible here then there is a connection/seating problem with the duplex tray)
Scroll down to copies and select 10
scroll up to print test page and press tick
the machine should now start duplexing 10 pages,
if you get the same error ( 1 page enters then jams)
it could be a dirty/snapped paper entry sensor,( looks like a little plastic match stick that protrudes into the feed path of the paper)
use a can of pressurised air to Blast any dust away from this arm and the surrounding area being careful to follow the Paper sensor Arm back to the sensor and blasting this as well-
Duplexer tray are cheaper than an engineer call out, if the fix above fails , your cheapest option may be a replacement Duplexer tray, available from most HP office equipment Stores as well as Belmonte Business Equipment.
Jul 23, 2013 | HP LaserJet 4250n Printer
Iam getting the duplex paper jam error 371 each time i try to print . how do imake the error go. i dont use the duplex at all.
See page 75 of the attached user manual on how to remove a duplex paper jam. If you can't find a paper jam in the duplexer, simply remove the duplex assembly (power off the printer, then power on) and see if that resolves your issue.
(The printer will operate just fine without the duplex assy. installed)
Okidata C9650 User Manual
Sep 12, 2012 | Oki Printing Solutions C9650 Led Printer
Mfc-8870dw duplex unit keeps jamming paper in the duplex tray
there are little rollers that grab the paper they can be worn out or debris on them causing it to jam. you can clean with alcohol and cotton swab. Otherwise you may need to bring it somewhere for service as there are a lot of mechanical pieces and hard to find out what is causing it to jam.
Mar 03, 2011 | Brother MFC8890DW AllInOne Laser Printer
How do i remove the duplex?
Here's an article on How to Install a Duplex Option on a Lexmark T64x Series Printer. Just click on this link: http://bit.ly/94TYQc. This is just to give you an idea on how the duplex option is installed. The duplex unit attaches under the printer, below the standard tray (tray 1) and above any option drawers (trays 2, 3, etc). Removing it is just a matter of lifting up the printer from the duplex option and then lifting up duplex unit removing it from the option drawers, if you have any.
Aug 05, 2010 | Lexmark T640 Laser Printer
Problems with duplex printing
So you're saying it will only pull paper from tray 1? This is likely because there is some setting that makes it think the paper in the other tray is not "normal" -- either thick paper, or a different size, or recycled. Check the paper type and size settings in the printer's menu, and also check the settings in the print driver.
The other tray that you want to duplex from is capable of duplexing, right? On some printers you can only duplex from specific trays.
May 27, 2010 | HP LaserJet 2300 Printer
T642 wont recognize tray 2 or duplex
You need to be sure you add the duplex unit and tray unit in the windows driver. The "device" tab will allow you to add the duplex and tray to the
printer.
Apr 29, 2009 | Lexmark T642 Laser Printer
C5100 okidata printer w/duplex but still can't print 2sided
You need to set installable options to duplex in your print dialogue box- or prefs somewhere. This is a setting up error
Apr 14, 2009 | OKI C5100n Laser Printer
Duplex unit
Open all the tray's and paper bins and exit bins and check for even a little piece of paper
Jan 16, 2008 | Panasonic FP-7760 Copier
88 people viewed this question
k24674
