Question about Garden
15.5 horse craftsman riding mower. Runs fine but acts like its out of gas when mowing. Dies but starts and runs fine for a few minutes. Dies 20 to 30 times in a hour and 1/2 as I mow lawn.
  • 41 Answers
Carb is probaly dirty
Posted on Jun 03, 2009
Have a black/decker electric mower that motor slows and dies while mowing.
Your battery is in its death throes and not charging properly. Ergo, it runs "out of gas" fast.
Mar 07, 2016 | Electric Garden
How do i fix the carburetor on a craftsman riding mower with a 15 horse briggs motor.
You may need to change the fuel filter, change and gap the spark plug, and adjust the valves.
Jun 14, 2014 | Craftsman Garden
Craftsman riding mower runs mows fine for about 10-15 mins then sputters out and wont restart tuill bout half hour later
two things can be doing this ,
(1) fuel tank pick up is broken in half and works till gas works it way down to break , proof of this is when u add more gas and it starts right back up
(2) breakdown in ignition system , this can happen in a few places (if I knew your model number I can tell u more) eventually It will fail and never restart
Jun 07, 2014 | Craftsman Garden
I have a 18.5 Poulan Pro riding lawnmower that runs fine untill I activate the blades. It then dies after mowing for a few minutes. I disengage the blades and it runs fine. Any solutions?
does it loose power then die or just shut off?does it run rough then die?try and run it with the gas cap loose th event could be plugged and the extra fuel needed to mow the vent might not be keeping up or a plugged fuel filter
Jun 06, 2012 | Garden
I have a troy built riding mower it starts up fine , runs 10 or 15 minutes, then it starts spuppering and dies. then it acts like its flooded when you try tostart it again. then the other day while tr
is it starving for gas the gas cap vent could be plugged keeping the fuel from flowing leave the cap loose and run it/are you loosing spark when this happens like the coil is going bad?
May 08, 2012 | Garden
Craftsman rider wont stay running
Once having the same problem with the B&S engine, I had to replace the ignition coil. When it is in the process of failing, it acted as you describe.
Apr 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
2 year old craftsman 42" deck tractor runs fine for 15 minutes then sputters and dies. Will start, run 2-3 minutes, die again. Leave sit will run for 20 minutes.
if it restarts immediately, check the vent in the gas cap for restriction. also, the solenoid on the bottom of the carburetor may be sticking or getting weak. if you have to let it sit for awhile before it retarts, the ignition module may be breaking down when it heats up. i'd bet on the gas cap or solenoid though
Sep 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mower dies after running for a few minutes
It sounds like the carburetor is running out of fuel.First make sure the tank is full then loosen or remove the gas cap when it starts sputtering to see if that corrects the problem. Then with engine off remove the fuel line that goes from the tank to the fuel pump,hold it low and see if any fuel flows out of it,if not lightly blow air backwards to the tank,(with fuel cap off),then see if the line is plugged. Next remove the fuel line that goes to carburetor from the fuel pump,crank the engine and see if any fuel flows,if so the carburetor should be cleaned by removing it and disassembling it.
Aug 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
359 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
