Question about Canon imagePROGRAF W8200 InkJet Printer
Error code E2813
We change carriage unit and printhead -at first the massege was check the print head and now error E2813 .when the masine start make more many nozzle check as usual.
  • 1 more comment
  • Shekh Nov 04, 2007
    E02813 error code on run up
  • Anonymous Apr 25, 2008
    Changed carriage unit w8200PG and printed two jobs then error message..."printhead error/turn off power" came up. Any ideas? Also, can anyone point me to a service manual in pdf?
  • kg56 Aug 29, 2008
    E2813 means: print head management error
    I know that you have to clean or to change the sensor, but I dont't know where this sensor is placed.
    regards
    klaus/germany karlsruhe
This means that your canon printer has had a ink discharge and is covered up and there is ink laying on the sensor, The sensor if it has went out is 20 bucks you can find at a canon parts retailer
Posted on Jan 25, 2008
In canon ipf 750 Error 03130031-2618
this is what i am finding out from other fixya site members so if this helps you out its them you need to thank...
Follow these steps :Cause: The Voltage of the print head is abnormal.
Problems can be with:
-Printhead -head relay PCB -Carriage relay PCB -Main controller PCB
Steps to be followed:
1. Replace the printhead. 2. Cable continuity check. if continuity of the cable between the head relay PCB and the carriage relay PCB is abnormal, replace the cable. 3. Replace the head relay PCB. 4. Cable continuity check. if continuity of the cable between the carriage relay PCB iand the main controller PCB is abnormal, replace the cable. 5.Replace the carriage relay PCB. 6.Replace the main controller PCB...
In my knowledge the error indicates the voltage on the print head is abnormal. It is an hardware related issue.
Possible cases can the print head is faulty or the relays to the PCB may be faulty or the PCB itself.
We have to perform continuity checks between the relays and between relays and PCB. then we can confirm if the relay is faulty or the cables between them . If not print head would have failed and needs to be replaced...
Hardware error. 03130031-2618
Turn off printer, wait, then turn on again.
03130031-2618 VH voltage error
Check the power supply unit
Oct 26, 2017 | Canon Office Equipment & Supplies
Gives message Printhead loose missing or not installed. changed several times same message
If you already replaced Print head then same error occur their might be a problem with the carriage unit. kindly check also if there is a leak inks on a carriage contact then clean it.installed again print head.
May 08, 2015 | Kodak 6150 AllInOne InkJet Printer
Error code 03130031-2618
It mean "Vh voltage error" and can be cause of short circuit in the printhead . Sometimes you can get good result with printhead changing, but it is not guarantied because of possible printer electric parts (carriage board, flat cable, motherboard or power supply) damage. For printhead changing, delete paper and use Service mode (hold Paper sourse + Information while switching printer on).
Apr 13, 2015 | Canon imagePROGRAF IPF710 Printer
Mx 316
Error 5100 typically means that something has jammed the carriage. Unplug printer, open, and examine the print area for anything that might be blocking the print heads from moving back and forth. clear...
Sep 07, 2014 | Canon PIXMA MP160 All-In-One InkJet...
How to fix u052?
Error U052 = Please check that print head contact pins of the carriage are not bent.
Or else you may need to replace
- Print head
- Carriage Unit
Jun 29, 2014 | Canon MG5150 AllInOne Printer
Canon iPF610 hardware error 03800500-2F2F and 03800500-2F30
03800500-2F2F/03800500-2F30 Head management sensor error
0014-0999
The head management sensor detected an ink discharge error.
A sensor sensitivity error was detected during head management sensor position adjustment.
Print head, head management sensor, or main controller PCB
1) Replace the print head.
2) Visual check
Remove foreign substances from the head management sensor if any.
3) Replace the head management sensor.
4) Cable continuity check
If continuity of the cable between the head management sensor and the main controller PCB is abnormal, replace
the cable.
5) Replace the main controller PCB
May 30, 2012 | Canon iPF610 InkJet Plotter Printer
How do I deal with the Check Cartridge U052 message
Solution 1:
  • Remove and replace the cartridges.
Solution 2:
  • Insert new cartridges
Solution 3:
  • Reseat the print head to correct print issues or clear an error.
Solution 4:
  • The print head is broken and it must be changed by a new one.
Source:
http://fix-your-printer.blogspot.com/2010/11/error-u052-on-canon-printers.html
Sep 16, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon pixma pro9500 mk2. error code b200. printhead problems. cannot access printhead, because it is locked in resting position due to error code. how do i get it to the middle? thanks!
PIXMA Pro 9500 MKII Error B200 = VH (Print Head Drive Voltage) is out of the specified value.
Need to :
- Replace print head and logic board at the same time.
or
- Replace Carriage Unit
or
- Power Supply Unit
Aug 17, 2011 | Canon PIXMA Pro 9500 InkJet Photo Printer
Canon Pixma Mp258 B200 Error
My printer is canon mp258 there was an error B200 . how t fix this?
Apr 07, 2011 | Computers & Internet
Error code 6A00 print head not moving. Sometimes
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Nov 18, 2009 | Canon PIXMA MP960 Printer
Canon imagePROGRAF W8200 InkJet Printer Logo
867 people viewed this question
Clive
Clive
old marine
old marine
