Question about Refrigerators
The refrigerator door does not close unless you press firmly on it, especially if there is a lot of weight on the door shelves. Can it be ''re-balanced'' so that gravity helps it to stay closed?
  • 21 Answers
Look at the door hinges;you should see some flat washers on the bottom of hinge.(maybe on top also).They are made with hard plastic or fiber,and are different thickness.You could probably use metal washers that you may have laying around.Loosen bottom hinge and pick up on bottom of door and hinge,and retighten hinge,someetimes this will solve problem.Other wise,may have to remove top hinge and lift door off and add washers till the door closes properly.When refrigerators are properly leveled,when you let go of the door,it should have a tenedency to close.Hope this helps Gregg
Posted on Jun 03, 2009
Refrigerator door keeps opening
Check the hinges are tight and seal in correct place to seal and stick. make sure no shelves are out of position stopping the door from closing properly, and lose some weight from the door if you keep lots of heavy bottles in it.
Apr 21, 2014 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
FRIGIDAIRE DOOR WILL NOT STAY SHUT
check shelving and stock in door not stopping door closing. Check hinges tight and complete (sometimes have a self limitting plastic stopper that breaks, allowing weight of door to pull itself open)
Apr 05, 2014 | Frigidaire FRU17G4JW Refrigerator
Fresh food door will not close/seal
Check to see if one of your door shelves is bigger (sticks out more into the fridge) than the other ones. If it is, theses shelves can cause door closing problems. Try removing the shelf from the door and closing it again. If this shelf is the problem, call subzero at 1800 222 7820 and give them your model and serial number, and they will send you a new standard depth shelf to replace the deeper shelf at no charge, these shelves caused a lot of door closing problems when they came out. Hope this helps!
Sep 07, 2013 | Sub-Zero 690 Side by Side Refrigerator
Fridge door hinges on right door dipping to the left how do i adjust
First take some weight out of the shelves on the door. To much weight in shelves will make door sag.
Mar 03, 2013 | Zanussi ZX99 / 5 Bottom Freezer...
The freezer door opens if the refrigerator door is closed hard
this is quite normal on a lot of fridges ! if it isnt closing again by its self you need to re-level the fridge and have it very slightly backwards . alternatively the fridge is not level side to side !. open the main door a third to halfway open and let it go, it should close under its own weight, if not adjust up on the hinged side leg or down on the opposite side , if the front legs are not not adjustable pull it out and adjust the back legs , a quick fix, is to chock up the front leg and all will be ok ,regards terry ps, clean the seals and the fridge where the seals make contact the seals probably do not need replacing unless the fridge is very very old. a lot of people replace seals when its not needed. regs terry
May 17, 2011 | Frigidaire Refrigerators
Do the door hinges ever wear out
I did my own search for the same problem and saw Dougs question and lack of a solution. I have the same sagging door problem and was looking for a fix.
First, when I removed the weight of the items from inside the door, the door closes properly. This means that the door is not very sturdy and cannot hold the weight of items placed on door shelving. There are NO adjustment mechanisms on the door hinges either. Bad on Amana. The GOOD NEWS is that I fixed the problem.
Take out all items from the door shelves. I removed the top hinge with the door closed to keep it from falling. I took the door off and placed it on the floor. The lower hinge has a plastic pivot over a steel pin - remove that for a moment. Place steel washers over the steel pin - about .080" or so thickness. Replace the plastic pivot. Replace the door. Add the normal weight of items back on the door shelves. The door closes perfectly. At least until the door sags again and I'll need to add another shim.
Jun 21, 2010 | Amana ABB2524DE Bottom Freezer...
Door not shuting rite doesn't seen to have a vacume seal
Look for something not pushed in far enough on the shelves and the Ice bin. Make sure the cabinet frame and the seals are clean. The doors should be closing on their own once they reach the halfway closed point. If all these are correct then the gaskets may be worn out, but unless torn they do not usually need replacing.
Eric
Oct 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer door opens when you shut the refrigerator door
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Sep 03, 2009 | Amana Refrigerators
Frigidaire FRT17G4BW9 doors not staying closed
Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Refrigerators Logo
235 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
