Question about Jura Capresso Impressa E75 Espresso & Coffee Maker
Cafe brews directly into tray, not cups
The system brews just fine, but all the coffee and old grinds are expressed directly into to bottom bin. I have taken the front of the unit apart to see what's going on, and it appears there is a hose disconnected. I would like to find a schematic of the the hoses, but cannot seem to find them anywhere on line.
does anyone have any idea where I can find an image of the inside of the X90. Or if someone has one can they take a picture of the inside of your unit for me.... I'm dying here.
    New Friend:
  • 13 Answers
Blazer,
I can help with this. I have become fairly well versed from owning two machines (an E-75 and an E-8) and having to repair them ocassionally. The guts in many of the Jura machines are typically very similar and utilize many of the same / similar components.
But it would be easier to handle via e-mail so that I can send pics of the inside of the machine and explain what's going on and what to look for. It will be much easier than explaining via this website. Just to alleviate concerns, it's most likely a simple o'ring issue.
I can be reached at mykr@yahoo.com.
Mike
Posted on Jul 05, 2009
Can't replace coffee grind drawer after emptying
That would normally mean that the brewing mechanism is not in the at rest or start of cycle position. Take the bin off the tray and see if you can slip the bottom tray back in now. Turn the machine on, let it run through the start up process and when completely stopped see if you can now remove tray and fit the spent grounds bin back where it should be.
Aug 25, 2015 | Jura Capresso Impressa E9 Espresso Machine...
The tray will not fit back in the machine, its jammed and I don't know how to reset the machine on a Jura F9
This happens when the try is removed before the brewing unit resets fully.
To fix is easy.
  • Remove tray,
  • Lift off grinds bin from the tray
  • Return tray to the machine with out the grind bin
Now you need to reset the brewing unit this is done by either
  • Starting a rinse cycle
  • Powering off and then on
Once you have don that return the grinds bin to the tray and it will go in.
Oct 28, 2010 | Jura Capresso Impressa F9 Espresso Machine
Espressione cafe roma problems with pump
The problem might be the tamping pressure or the grind?
Jun 28, 2009 | Espressione Cafe Roma Deluxe 1329
Espresso irregularly spurts out the center post
could it be that the gasket is oversized and it covers the small holes ?
Mar 08, 2009 | Bialetti Mukka Express
Cuisinart Grind and Brew 10 cup coffee maker warm water leaks from bottom during brewing.
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Oct 12, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Revere Ware old fashioned coffee pot
1) Boil the water you’ll need in another pot.
2) Put 1 tablespoon of ground coffee (drip grind, not percolator grind) in the reduced diameter, perforated bottom of the brewing chamber.
3) Put the grind/water separator (the perforated, flat handled plate with cup markings on the handle) in the Brewing Chamber, over the coffee grounds.
3) Put the Brewing Chamber on top of the Holding Chamber.
4) Pour the appropriate number of cups boiling water into the brewing chamber; put the lid with the black knob on the brewing chamber.
5) Let the water drain through the coffee grinds (5-10 minutes).
6) Remove Brewing Chamber, clean out the coffee grounds, and replace the lid on the holding chamber.
7) Enjoy your coffee! Keep it warm on the stove at LOW heat setting.
for the most information on the Revere cookware lines, go to: http://mysite.verizon.net/vzeoywo4/theshineshop2/id1.html
Charlie
Jun 16, 2008 | Coffee Makers & Espresso Machines
Directions on how to use my Black and Decker Espresso Mio coffee maker
Be sure the red rubber gasket is in place and clean (ridge side in) and bottom water cup is screwed firmly on to avoid leaking.
HOW TO USE:
1) Fill the bottom water cup with cold water up to the inside lip.
2) Set funnel into bottom water cup
3) Fill coffee basket with expresso grind coffee and level off. (Do not tamp or pack). Make sure it's filled to the top.
4) Place filter onto coffee basket and set coffee basket into funnel
5) Place brewer over bottom water cup and screw firmly into place.
6) Place unit with lid in the center of a microwave oven set on high for 1-1/2 minutes. If boil over occurs, reduce the brew time in 10-second increments until no boil over occurs.
7) Grasp handle to remove unit from microwave when finished brewing.
8) Remove lid and check the level of espresso in the brewer cup. Standard brew is at least 2 oz. If you don't have this level brew, replace lid and microwave on high another 10 seconds. Wait 20-30 seconds for bubbling to stop.
CLEANING/ADDITIONAL BREWING:
1. Under cold running water, unscrew the bottom water cup. CAUTION: It is normal for some water to be left in the bottom water cup. Both the coffee basket and any water in the bottom water cup will be extremely hot! If you prefer, allow the unit to cool for at least 3 minutes before unscrewing it.
2) To brew additional espresso, rinse Funnel, coffee basket and filter, then repeat brewing steps 1-8 above.
3) Parts are top rack dishwasher-safe -- hand washing filter is recommended.
Mar 10, 2008 | Coffee Makers & Espresso Machines
Cuisinart Grind & Brew not using all the water in the reservoir
I was having problems like this and then I read on a different string on this website that people have had success by flushing the system numerous times (sometimes up to six times) with vinegar. I took out the charcoal filter and flushed once with vinegar but only saw a small amount of improvement. I was out of vinegar so I used Lemishine mixed with water and it went from making one cup to making a full pot with one flush.
Jan 10, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Jura Capresso Impressa E75 Espresso & Coffee Maker Logo
234 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
