Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
E30 user guide comes up but checked the belt and the brushes they about half inch long is that long enough or to short
  • 30 Answers
Motor tacho failure replce motor
Posted on Jun 09, 2009
Replacing belt on brushroll on a Hoover SH40060 canister
Your manual is pretty lacking. Most all brushes have holder guides on both ends, normally the entire brush and guides will lift straight out of the head if the belt is broke, there could be a locking clip, make sure the area is clean so you can see it, but the brush head has to come out somehow or a new belt can't go on, some have the top of the head comes off, the cover, this way you place the belt on the brush, set the brush back in the head, then you set the belt onto the motor shaft from the top.
What ever you do, make sure you watch how the brush comes out and the guides, if you need to take a marker and put a mark on the guides so you know what the top was and how they go back in.
Apr 03, 2013 | Hoover Platinum Cyclonic Bagless Canister...
Se1000 washer will not pump all of the water out on spin cycle
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Coming the second aspect if the above gives no result:
Perhaps you need new carbons brushes for the motor. It is a fairly straightforward repair. Remove the top cover, screws at rear, and slide top cover off towards the rear. The motor is located at the top right right rear, you will see the drive belt. Slacken the bolt that holds the motor, and push the motor down towards the top of the drum. You will see the 2 brush holders, they will be either black or white, pull the wires off the holder terminals, and depress the plastic lug that holds the brushes in place, slide the brushes out of the motor. The length of the brush should be at least half an inch long or replace. Fit new genuine carbon brushes, and follow instructions on packaging. Push the leads back on to the carbon terminals. tighten up motor, and make sure the belt is reasonably tight. Test on final spin before you refit top cover.
(Spares can easily be located on this very site - Fixya)
There are very gud videos on YouTube to guide you.
If helped pl click so.
Mar 24, 2013 | Washing Machines
Hotpoint ultima 1000 wm74 cod E30 'user other guide' , machine doesn't work with any programs, don't know to do
  1. E30 means a motor drive problem has occurred. Motor problem - check motor brushes, drive belt, tachometer or tachometer magnet, motor relay or PCB (TRIAC motor control).
  2. The main control board in these machines has a relay that may fail because of bad solder joints. You will need to unpin the board to see behind where the white wires from the motor connect to this board, you will find the relay near to the edge. Check the solder joints for damage.
Feb 12, 2011 | Washing Machines
Neff washing machine not spinning. Fine yesterday, slightly funny noise and now drum not moving on wash or spin! Any clues?
Could be worn Carbon brushes on the motor.Check belt has not fallen off though...some Neff you need to buy half motor to fit new brushes as it comes this way, perhaps a good test is to blow ut any dust next to the brushes this may allow the motor to Briefy run long enough to tell if brushes are worn ..Half motor cost to buy - 60 GBP......Happy new year...
Jan 02, 2011 | Neff Washing Machines
My kirby g5 is not picking up, there is no blockage, but suction has dropped significantly, what could be the problem?
Not to question your description of the problem, but are you sure the suction has dropped? Kirbys don't usually lose suction unless there is a mechanical or electrical problem. When you turn the machine on does it fill with air and expand? If so, then you probably have enough suction. If the bag doesn't fill and expand and your machine is extremely noisy then the fan may be broken and need to be replaced. If you see excessive sparking near the bottom of the handle then you may have a motor problem like stuck or too short carbon brushes or a bad armature. On rare occasions, with Kirby owners who live close to a beach area and vacuum large amounts of sand, the sand actually wears down the vanes of the fan enough to make it useless. To check the fan; first unplug your Kirby from the electrical outlet, remove the brush roll nozzle, slowly spin the fan/belt pulley while observing the surface of the fan, look for cracks or breaks. The fan vanes should be about 3/4 of an inch deep.
If none of the above fixes your problem, look at the brush roll and belt. If your belt has not been changed in the last 12 months, install a new belt. If this is the original brush roll, install a new brush roll.
May 18, 2010 | Kirby G5 Bagged Upright Vacuum
What is E30 ?
E30/31: Motor problem - check motor brushes, drive belt, tachometer or tachometer magnet, motor relay or PCB (TRIAC motor control).
Jan 28, 2010 | Hotpoint Ultima WD72 Front Load...
My hotpoint washer/dryer keeps coming up with code e30 see user guid and stops washing,what does that mean
Error code E30 indicates motor tachometer failure.
There is a loss of signal during tumble or spin.
Check your user guide.
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Delicate cycle stopped on rinse
Remove the front lower panel, screws underneath. Be prepared for water, drain out from drain hose. Check filter for clogging, clean out. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if it is any shorter than 5mm replace brushes.
Apr 02, 2009 | Bosch Classixx WFO 2466 Front Load Washer
Error code e30 see user guide .comes on and stops washing do not have user guide
E30 is a motor problem which is most likely brushes need replacing.
Hope this helps & Thanks for using Fixya.
Jan 18, 2009 | Washing Machines
Hotpoint ultima 1200 wm72
code e30 means motor fault. this can be just motor brushes, tacho fault or module fault. can't narrow it down more than this - you will have to dive in and check
Apr 05, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
136 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
