Question about Dell UltraSharp 1905FP 19" LCD Monitor
Monitor will not power on....
I recently moved my system.  Upon reconnection my monitor will not power on AT ALL.  What could be the problem?
  • 1 more comment
  • nanuq Nov 25, 2007
    I have the same problem. After doing all the troubleshooting I could think of, I am told I will have to replace it. Don't have money for that, so would like to know what repairs I could try.
  • Amus22 Feb 04, 2009
    My monitor also will not power on.
    I disassebled the monitor and it is not the switch.
    I once saw a power supply module for this monitor for sale on-line, but cannot find it now.
    Does anyone know if a replacement is available?
  • Anonymous Mar 03, 2009
    Also when i moved my monitor stopped turning on at all, but i think it might just be the power button. So i was going to try and take it apart and see if that is the problem, now i just have to figure out how to get it apart.
I just repaired one. Symptom was no power at all. When I plugged it in, I could hear the switching supply making a noise, like it was trying to turn on. I opened it up and It ended up being 2 capacitors in the power supply section. I seen the tops were swollen, they were 1000uF 10V. They were for the 5volt power section I believe.
I think they were C824 and C825. I removed both of them and replaced them with one 2200uF 10V cap. I powered it up and it works now.
Posted on Feb 23, 2009
It seems that the 1905FP has a problem with a faulty power connection. I have had a few of these that work fine then all of a sudden it stops working and have found that if the power is held in a certain position it will work just fine.
Posted on Feb 10, 2008
  • 156 Answers
Loose connection of adapter or power socket
Posted on Oct 24, 2007
Dropped keyboard. Now display on monitor says 1. Analog input in power save mode - press any key or move mouse to turn on. I have done both, neither works. I have turned off system and I see it rebooting...
the message Analog input in power save mode means that your monitor is not getting a signal from your computer.
Maybe you moved the video cable while reconnecting your keyboard? check both ends of your video cable.
If you have a DVI cable, then your monitor has to be switched to digial input.
I hope this helps.
Nov 10, 2017 | Dell UltraSharp 1708FP 17" LCD Flat Panel...
Upon startup a gray box appears reading "frequency out of range"how do i fix it? 95kHz / 120 Hz Please change it to 1280 x 1024 with 60. i have set the computer up with another monitor and it works just...
Reconnect the "other" monitor.
Right-mouse click anywhere on your desktop "wallpaper".
Click Properties.
Click Settings.
Move the slider to 800 by 600.
Click Advanced.
Click Monitor.
Change to 60 Hz.
Click OK.
Reconnect the LCD monitor.
It should display your desktop, at 800 by 600 by 60 Hz,
including that "Properties" page.
Move the slider to 1280 by 1024.
Click Apply.
If you can see the "prompt", click OK.
If you cannot see the "prompt", wait 15 seconds,
to revert to 800 by 600.
Slide to 1024 by 768, and click OK.
Jan 04, 2010 | Princeton Digital VL1918 Monitor
Monitor wont power up
It is possible especially if it has a loose or slightly faulty component and moving the monitor has caused it to fail especially if you bump it in the move.
Does the power LED light up when you switch on the monitor?
Sep 06, 2009 | Dell UltraSharp 1504FP 15" Flat Panel LCD...
How do we turn off the POWER SAVING MODE on the monitor screen?
Try going into your Start Menu then going into your control panel...then clicking on your "power options"....then switching the options to 'always on'..if this does not work..(as it seems you may not be seeing this because the monitor is in power saving mode) try fiddling with the setup option on your monitor and find a possible powersaving mode enabled function and disable it. every monitor is different so I couldn't really help you here...if this doesn't yield results try another monitor to see if it's the monitor having the problems or the computers video card...the video card could very well be the culprit...
Apr 08, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Cornea CT1700 monitor has no power.
i think that is not monitor problem, that is your computer (cpu) problem.plase chack your ram memory,open your cpu door and remove your ram and clean it with cloth and restore back.your problem will be solve thank you.
Dec 22, 2008 | Cornea CT 1700 17" Flat Panel LCD Monitor
Not powering on
it also happened to me, but i tried to reconnect the connection to my cpu and the power cable of the monitor, and its ok. But after a while my monitor get black again. what i do is i turn my computer off and check again the power cable of my monitor, reconnect the monitor to my pc and i opened my cpu, check my memory card, i reinserted it. And it worked.
hope it also work for you
Sep 17, 2008 | ViewSonic VA550 15" Flat Panel LCD Monitor
Can't hear any sound from the large left or right speakers
is sterio in a ch ? not b or is it in b and not a when u hooked it back up
Jan 26, 2008 | Technics SA-AX540 Receiver
LED's blinking, no video
Your C5707 transistors in the monitor have failed. Suggest replacing all four with the Sanyo C5707 transistor. A common problem.
Dec 10, 2007 | Dell E173FP 17" LCD Monitor
All three LED's blinking, no video
hi, does the three lights blink only after u connect it to a display card??if yes then check if any of the connecter pins are damaged, or check out the display card..bye let me know
Dec 08, 2007 | Dell E173FP 17" LCD Monitor
Monitor switching to standby - CV735 monitor with Presario 5000 series desktop
my compaq crt monitor not showing color. its shows only blue, green colors . u please tell me. what is the problem to solve it.
is the monitor fault or any other.
Oct 30, 2006 | Compaq CV735 17" CRT Monitor
Dell UltraSharp 1905FP 19" LCD Monitor Logo
796 people viewed this question
Alun Cox
