Question about HP Officejet Pro L7580 All-In-One InkJet Printer
I can not install my HP Printers Officejet-- gives fatal error
I can not install my HP Printers Officejet pro-L7590 & J6480 even after countless hours with 3 HP techs, it gives fatal errors 2753 and MSI.dot4wrp.
    Scholar:
  • 169 Answers
This issue requires some serious trouble shooting and solutions cannot be posted as they are too long.
If you want further support you can avail free technical support on http://tinyurl.com/m7ghqz
Posted on Jun 19, 2009
  • 49 Answers
Solution 1>
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
solution 2>
complete uninstall printer software from computer.
run uninstall L1 L2 L3 L4(if not an hp computer).
run same uninstall l1l2l3l4 from 7z..folder or hp folder from temp if availalbe.
then clean from add remove programs/program and features.
then clean from cleanup utility all hp pritner related entries.
then clean temp folder. clean recycle bin.
delete c:\program files\hp and hewlett packard folders (if not an hp computer). on hp computer delete digital imaging bin folders.
delete following folders from following locations-
C:\windows\System32\Spool\Printers and deleted entries inside it
C:\windows\System32\Spool\drivers\w32x86\*.* deleted entries inside it
C:\windows\twain_32.
cleanup from regsitry--
plz make back up for registry first.
>> hklm/system/current control set/control/print/environment/windowsNT(x86/64)/drivers + processors delete all pritner entries from there.
>> hklm/system/current control set/enum/usb/vid_000,vid_003 delete.
>> hklm/system/current control set/enum/usbprint delete pritner entries.
>> hklm/system/current control set/control/print/monitors/hp standard tcp/ip ports/ports.
>> hklm/system/current control set/control/print/monitors/standard tcp/ip ports/ports.
>> delete same ports from printers and faxes/pritners pritner properties ports
>> hklm/system/current control set/control/print/monitors/hpz..
>> hklm/system/current control set/control/print/providers/lan man settings.
>> hklm/SYSTEM/CURRENTCONTROLSET/CONTROL/PRINt/PRINTERS
>> hkey_Current_User\Software\Hewlett-Packard
>> hKey_Local_Machine\Software\Hewlett-Packard
>> HKEY_USERS\.DEFAULT\Software\Hewlett-Packard
>> hkey_current_user\software\hewlett packard delete if not hp computer.
>> hkey_curent_configuration/system/current control set/control/print/pritners.
then go to msconfig
make it selective startup disable all microsoft services except hp services. hide all microsoft services. disable all startup tab apply restart.
after restart install cue version 12 officejet pro 8500 or 6500.
then run msiexec.exe /unregister then msiexec.exe /regserver cmd commands.
then install software from downloaded version of original pritner install only basic drivers first and imaging devices only and use solution center 12. cue 12.
issue resolved.
Posted on Dec 14, 2009
  • 32 Answers
Dear gerrih,
I watched your case and observed that you are facing fatal errors 2753 and MSI.dot4wrp while installation.
in this case first you check that is their any HP Printers Officejet pro-L7590 driver is installed on your pc if yes then turn off your pc and your printer both now unplug U.S.B cable from both ends.
here turn on your pc once and then delete that driver.
now insert your driver cd in cd-rom and run installation again.
if problem persits contact me again.
thanks
Posted on Jul 31, 2009
Why do i get hp l7590 no ink error on new cartridge?
Did you remove the plastic tab or plastic strip prior to installation? I assume you did and then the cause would be a clogged print head. This usually happens if the printer has not been used for a long period.
Aug 30, 2014 | HP Officejet Pro L7590 All-in-One InkJet...
Imaging device not found l7590
The best thing to do is uninstall the printer driver and re-install it , give this a try if you dont already have it fixed good luck Roy
Jan 08, 2012 | HP Officejet Pro L7590 All-in-One InkJet...
Scanner does not work It keeps telling me "no conncetion to computer" but the printer is conected . I can copy from the computer. Wher can I find an instruction manual for Officejet Pro L7590 My last HP...
The Driver of the scanner and driver of the printer, this two miscellaneouses of the driver, in addition is fixed. Attentively install both drivers with mounting disk. Else use the cable USB from kit of the supply, scanner can not work since long шур USB.
Sep 25, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Says that I need ink even though I just replaced it
Replace all the ink cartridges??????? If this is HP's idea of how to sell more ink my printer will be floating down the Ohio River very shortly.
May 21, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
GETTING A FATAL ERROR MESSAGE AND MSI CODE 2203 ON HP L 7590 prin
Visit the below web link and perform the steps provided in the document
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00459898
if the issue still persists,
perform uninstallation and installation that should resolve the issue
Nov 15, 2008 | HP Officejet Pro L7590 All-in-One InkJet...
Can't get the HP Officejet Pro L7590 AIO to Install Properly
When you are installing the L7590 you will get a screen that ask you if you are hooking up usb or ethernet. click usb. then the next screen will detect the printer do not plug your usb clble into your computer until this screen. I have found that if it gets past step 5/8 you shopuld be good. However it might still error out on step 5. I have installed many of these and got the same error many times and found that this is the best solution i have found.
Oct 15, 2008 | HP Officejet Pro L7590 All-in-One InkJet...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
1,149 people viewed this question
Seeker5211
Seeker5211
