Question about Samsung LE32R73BD 32 in. HD-Ready LCD Television
No digital yet tried to retune but greyed out.
I have connected the ariel to the back of the tv and originally we received all the digital channels. but since the tv system was switched off the digital channels are no more - the option for retuning the channels is greyed out and no matter what i try i just can't seem to retune the digital channels or view anything. Yet when i switch to analogue i receive BBC1, BBC2, ITV1, Channel 4 and a very weak channel 5.
  • techguy7 May 11, 2010
    Hi
    Could you provide the model please?
  • Darrell Brooks May 22, 2013
    Ez-TV646
  • 6 Answers
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Posted on Oct 05, 2009
    President:
  • 1,653 Answers
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit
http://tvretune.co.uk/productmanuals
Posted on Oct 03, 2009
  • Trevor Davis
    Trevor Davis Jun 15, 2015
    Thank you formatt40 the info, menu, mute, power sequence worked although if anyone tries it as I had to, you might have to do it several times but the hidden menu will eventually appear.
The tv is fine without the freeview box have tried new scart lead also new tv ariel leadand retunned several times
Are you getting any reception at all? Could it be that the antenna is not receiving the signals??
Jun 11, 2014 | Cameras
Sony KDL-32NX503 I have no channels 1-9 after retuning.
Do a factory reset to this set. Refer its user manual for details.
Apr 22, 2012 | Sony Televison & Video
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
After digital switch over in the east midlands and retune of the tv only can receive BBC
This is most likely due to the fact that your Ariel is not set up to the right station. You should call an Ariel erector to either change the Ariel or move it to the right position.
Hope this helps
Apr 13, 2011 | Televison & Video
How do I , or in fact can I, tune the DVD recorder such that it can see the digital TV stations - all I get at the moment is analogue channels
can you receive digital channels through your tv (if it is a DAB TV)? The reason i ask is that you may not have a strong enough signal to receive digital channels. Try taking the dvd recorder to a friends house and plug it in there to see if it will tunethe stations in. IF it does try it back at yoursto see if it will pick up the channels if it breaks up the picture then you need to upgrade your ariel
Mar 11, 2011 | LG RHT397H DVD Recorder
I have retuned my parents tv but now the digital (freeview) channels do not have the correct channel numbers and I cannot find anything in the manual as to how to change them. For example, freeview channel...
It sounds like the TV has re-mapped the channels incorrectly. You possibly can contact Toshiba to see if there is a firmware/software upgrade that will fix this issue. If there is you may be able to download the software off of their website and install yourself. Just make sure if that is the case follow the directions carefully. Please take a few moments to rate my answer. Thanks..
Nov 19, 2009 | Toshiba 32WLT58 32 in. LCD Television
Lost channel info for channel 5 on my DVR Digifusion FVRT 145 since end of sept. Most other listings are still being downloaded
First I emtied all listings by retuning with arial unplugged . then did full channel search with ariel reconnected . Left unit on standby overnight all channel listings reapeared.
Oct 05, 2009 | Digi Televison & Video
Retune process stalls
For specific model information visit http://tvretune.co.uk/productmanuals/
Oct 01, 2009 | Goodmans W280NS Television
Resetting a sony television to receive digital programs
The retuning process is as follows:
  1. Press the [i+] or MENU button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
Nov 10, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Samsung LE32R73BD 32 in. HD-Ready LCD Television Logo
1,548 people viewed this question
Jerry Greenberg
Jerry Greenberg
