Question about Nokia 5800 XpressMusic Smartphone
Nokia 5800 backlight problems
When i lock my nokia 5800 the backlight stays on, it has only just started doing this and its wasting my battery. how do i fix it?
  • Anonymous Mar 25, 2014
    it refuse to come on after soldered the battery terminals back
On a computer install the nokia software updater which is included on the CD in the box. Perform a software update to the most recent version and this should solve the problem.
My phone had this problem (after having it for around 4 months). After performing the update the issue was resolved, hope this helps
Posted on Jun 13, 2009
Unlock my nokia 5800 xp
To get the Unlock code for the Nokia 5800 Express Music you can reach the site Mobileunlocksolutions.com and buy it ,unlock it,specify the current Network and Country it locked now?Because there you can unlock code for some countries GSM Network not for all,You can enter the code correct using the instructions below:
Nokia 5800 Express Music Unlocking Instructions:
Warning : Do not enter any wrong unlock codes on your Nokia 5800 XpressMusic mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 5800 XpressMusic mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 5800 XpressMusic without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5800 XpressMusic.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5800 XpressMusic would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5800 XpressMusic mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
Nov 27, 2011 | Nokia 5800 XpressMusic Smartphone
Unlock code nokia 5800
Nov 27, 2011 | Nokia Cell Phones
How to remove the country lock?
Which Network,in which Country It locked too?
Because all Network lock cannot be Unlocked...I have Unlocked My Nokia 5800 Express Music Using the UNLOCK CODE.So you can use the Unlock code to Unlock the Phone,You can get the Unlock code from here
Theunlockarena and Unlock it....You can follow instructions below and unlock it step by step..
Nokia 5800 XpressMusic Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Nokia 5800 XpressMusic mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 5800 XpressMusic mobile phone, your phone may get hard locked and sometimes become unusable.
Jul 29, 2011 | Nokia 5800 XpressMusic Smartphone
How to open line nokia express music 5800
Which Country's Network Lock Do you need it open from ?
To open it from the Network Lock,get the Unlock code and instructions from
Mobile-unlocker and Unlock it.You can follow the instructions below and Unlock it step by step:
Nokia 5800 Express Music Phone Unlocking Instructions :
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5800 XpressMusic
May 31, 2011 | Nokia 5800 XpressMusic Smartphone
Nokia 5800 do not start only vibrate due to software update prob.
yes this is a very huge problem facing by 5800 holders don't worry if ur phone in warranty period u should go nokia care and reinstall ur software and if not than u can also resat ur phone by holding green button along with red and camera button while switching on position
Feb 10, 2010 | Nokia 5800 XpressMusic Smartphone
Songs r locked in nokia 5800
Hi
The problem you are facing can only be solved at a Nokia Care Center, becuase the songs loaded in the Nokia 5800 memory card are locked with a key, which is available only at Nokia Care centers, i faced similar problem with my handset and had to visit Nokia Care to get my songs unlocked again.
This problem occurs if in case you do not have a back up of your phone content before doing a firmware upgrade and happens mostly with users having a new phone who directly go to do a upgrade.
Please carry proof of purchase of your Nokia phone along with you when you visit Nokia Care
Dec 01, 2009 | Nokia 5800 XpressMusic Smartphone
Nokia 5800 music xpress display problem
Sounds like the connection from the phone and ur touch screen is loose. Would suggest getting a technician to fix it. There are online resources that also show you how to do it.
Aug 17, 2009 | Nokia 5800 XpressMusic Smartphone
Nokia 5800 xpressmusic backlight not turning ON
Hi Friend,
As you have mentioned that you are not able to turn on,this may be due to the follow the reasons,
1.Kindly check the display,if there is a problem in the display you will face this kind of problems.So kindly change the display and check it out.
2.Try by doing a hard Reset as follows
a.Switch off the Mobile
b.Remove the simcard,battery and the memory card
c.Hold the Switch on/off button for 20 to 30 sec's
d.Now replace the sim card and the battery alone,switch on the mobile
e.After the mobile switches on now insert the memory card
Check and revert back
Thanks for using Fixya
Regards,
Ayyasam
Jul 13, 2009 | Nokia 5800 XpressMusic Smartphone
Nokia 5800, will not turn on
i think u did nto unlock your phone or there is a problem with the network sim u use.
Jun 21, 2009 | Nokia 5800 XpressMusic Smartphone
Nokia 5800 XpressMusic Smartphone Logo
915 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
