Question about Datel Action Replay for Nintendo DS
My Action Replay DS code manager is not recognizing my AR DS!
Help mee! plez plez plez plez plez!
I have the same problem
Posted on Jun 04, 2009
SOURCE:
My action replay wont be recognized!
make sure your usb cord is plugged in to your DSi AR and computer. **do not have the AR plugged in to the DSi.
then put the AR's CD ROM in.
you go to start menu.
type in device manager.
right click Dsi AR...
click the driver tab.
click update driver.
click browse computer.
then check the box [subfolders].
BROWSE.
find DSi CD ROM folder.
and voila! :D
it should work
Jul 13, 2010 | Datel Action Replay for Nintendo DS
I dont have the cd for the action repay
if u dont have the ar cd, that's ok. you use the cd and ar cord to install the action replay code manager. if you go to a website like neoseeker or supercheats that has action replay codes posted, you can copy a code and then go to the ar code manager and add it to your codelist. i only use the code manager for really long cheats. you can still enter cheats manually to ur ar, but without the disk, you cant quickly put long cheats onto ur action replay. you can get an ar disk at walmart, target, or gamestop. sorry if this is too long, but i hope it helps.
Jul 14, 2009 | Datel Action Replay for Nintendo DS
I downloaded the AR code manager,and it doesnt recognize the AR
Then your ds card slot where you put the game or action replay might need cleaning i use a dry Q-tip and rub very very gently or your action replay is busted :P hint do not put in too many codes my mistake let just say its a magic eraser :P
Jul 02, 2009 | Nintendo DS Lite Console
Action Replay code manager won't recognize DS
Go here: http://www.datelcustomerservice.com/product_help/NDS_ARDS_Help.html#WinXP. Scroll down to "Q: My Action Replay is not being recognized by the Code Manager Software, it just says waiting for DS in the left window; what do I do?" click that and read & follow the steps carefully.
May 30, 2009 | Datel Action Replay for Nintendo DS
Action Replay deleted all of the cheats for Nintendo DS
you can reconnect your ds+AR and you can put the codes back on there by clicking and draging one of codes list from codejunkies.com if you have your Action Replay Code Manager installed, which should come on a disc you bought with your AR
May 29, 2009 | Datel Action Replay for Nintendo DS
My Ds Action Replay Went BLANK!
i have had a similar prob it wiped all the games andm then i could not put more on because it went multi coloured when i tried so i hap to reset the entire thing to do so(source codejunkies):
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems:
* Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes.
* Code Manager PC software is reporting the console`s battery is low when it’s actually fully charged.
* Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes. * You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased.
  1. With your console powered off insert the Action Replay DS
  2. Hold down buttons A+B
  3. Turn your console on
  4. With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down
  5. Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen
  6. If Action Replay DS doesn’t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
copyed from code junkies
Mar 20, 2009 | Datel Action Replay for Nintendo DS
Action replay code manager doesnt see the action replay
Many are experiencing this, what you are looking at here is a faulty action replay. go to the Datel website and submit your serial number to them, it will immediatly say whether or not your AR is from the time period when they had a problem with the internal USB reading system, if it is, then send it in and one will be shipped withing 10-12 weeks
Jan 15, 2009 | Datel Action Replay for Nintendo DS
Action replay when i plug in my ds and load code manager it says waiting for ds even though it is plugged in
IF you are running Vista 64, the issue is the driver on the disk is incompatible, thus the pc will never see the ds. However, I have found a workaround. First make sure the DS is on and plugged in and the Action replay Manager is launched. On the DS click on the mouse so it should read updating software. Then, go into device Manager via the Control Panel, there you will see NDS and an exclamation mark. Right click and choose to update the driver or properties. Then choose Browse My computer for driver software... then let me pick from a list... then fo the manufacturer shoose: Standard USB Host Controller and for the Model choose Unknown. It will pick it up instantlly. Voila.. Good Luck! and what a pain!! V
I’m happy to help further over the phone at https://www.6ya.com/expert/vicki_52d4aba3abce9140
Aug 21, 2008 | Datel Action Replay for Nintendo DS
Datel Action Replay for Nintendo DS Logo
355 people viewed this question
Top Datel Video Game Consoles & Games Experts
Trimesh
mark gardner
mark gardner
Marvin
Marvin
Are you a Datel Video Game Console and Game Expert? Answer questions, earn points and help others
