Question about Kenmore Energy Star 44092 Front Load Washer
Model # 417.40042990 makes awful noise when spinning, took back off and discovered a rusty spray from the back of the drum/tumbler.
  • 6 Answers
SOURCE: Clanking noise during spin cycle
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
Posted on Feb 13, 2008
  • 188 Answers
SOURCE: Kenmore HE3 Front Loader Washing Machine tumbler
The metal basket (inner basket) has a broken spider (these are the support brackets that hold the basket to the bearing shaft). The inner basket will need to be replaced and the front and rear shell of the drum may also need to be replaced depending if any other damage has been done. It's a big job, about 2 hours for a good tech.
Posted on Feb 19, 2009
  • 77 Answers
SOURCE: will fill and drain but won't spin without assistance.
The safety switch could be broken or loose. This switch tells the machine that the lid is closed so that it only spins with it closed.
Posted on May 13, 2009
  • 109 Answers
SOURCE: Kenmore model #417 40042990 Front Load Washer is
I would firstly take the back cover off and check the belt has not come off. Then check that the drain pump is not blocked.
Posted on Jun 16, 2009
SOURCE: Over loaded my front load lg washer and now it is not able to spin. Makes awful grinding noise. Is this something I can fix myself?
this hapened to me years ago it was an easy fix I took apart my washer ther should be a belt that almost looks like a belt off a car it probably went off track once you get it apart try spinning the belt you should be able to fix yourself
Posted on Jul 06, 2012
Everything works but it is making a awful noise when spinning like sand and metal is grating
Sounds like drum bearings may be bad. They use make horrible almost screeching noises. You would need to look up your particular ubit. On some they are integrated into the drum as an assembly and replacement is expensive.
Oct 17, 2016 | Dryers
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
When entering spin cycle, making a loud noise. I
Check your belt it may be lose. A lose belt will cause a squealing noise and the machine spin slower or take time to come up to full speed
Oct 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
Kenmore Model 925 75 110 washing machine makes loud noises when the spinning cycle ends (as it stops spinning). Any ideas? Ease of repair ?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
There is also an excellent PDF document from Whirlpool describing how Direct Drive washers work.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
We has the same basic problem with a Kenmore direct drive washer. At the end of the spin cycle we heard a loud noise as the brake stopped the drum from spinning.
Sometimes, what can happen is that the brake will grab the brake drum, like a brake on a car suddenly locking a wheel.
The brake is supposed to slow down and stop the drum without locking.
We were able to spray a small amount of silicone spray inside the brake drum, which allowed the shoes to more gently grab the drum.
See GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Remove the cabinet and look at the drum directly above the silver colored clutch assembly.
Using an spray can of silicone spray, and a directional tube, spray a very small amount into the brake drum.
Sep 25, 2009 | Kenmore 22422 Top Load Washer
Dryer is making an awful squeaking sound
two things- belt or drum. un plug machine for safety, visualy inspect belt, place machine on its side to see it make sure its clean, no rips and not loose. it is easy to replace, just note the way it is on before you take it off. stand machine back up,next try turning the drum by hand, if you feel scaping or hear odd noises, it needs to be removed, may be foreign object or needs felt replaced. if you are fairly handy, you could do this too
Aug 09, 2009 | Dryers
Dryer won't spin, but heats up - belt is okay
the motor may have seized up, or the drum bearings are shot.
Jun 19, 2009 | GE DBL333EA Electric Dryer
Loud squeaking noise
dont spray that on the belt lol that stuff is flamable i think lol you most likely have bad phelt glides  they are pads that sit between the drum and the drum support and when that wears out it squicks or maybe you have a bad idler pulley which is what holds the belt maybe its rusty or something but most likelt its the pads
Jun 09, 2009 | Maytag MDE6000 Dryer
Electric dryer makes a rumbling when tumbler is turning.
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.The bearing is at the base of the drum and accessing it is not easy.
You can find diagrams and replacement parts entering model number here.
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Something rattling under the drum
Strangely enough, I found the problem to be in the motor. If the noise becomes pronounced during the high speed spin cycle, then that is the problem. I had a repairman out for mine and they wanted to replace the drum, however when I took off the back and removed the belt, I could turn the drum separate from the motor and could hear that the problem was in the motor bearing, not the drum. Hope this helps.
Nov 18, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
60 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
