Question about Carrier 52CE-307-3 Air Conditioner
CAN'T GET COMPRESSOR TO COME ON ON MY XE 1000 TRANE
REPLACECE CONDENSOR AND FAN MOTOR NOW COMPRESSOR WON'T WORK HELP
  • tjohn2 Jun 04, 2009
    start capacitor is new. fan motor and run capacitor are new. worked about a week., now only fan will run - the compressor will not kick in. while it was working it was blowing cold - pretty sure it's not low on freon.
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    Condensor? or did you mean capacitor like the motor run capacitor for the fan or the start capacitor for the compressor?
  • 585 Answers
Often when I work on something and it quits after a short while it is the result of something I disturbed in making the repair. I would check the connections to the compressor, the start/run capacitor, and the low pressure switch if there is one. Sometimes the slip-on terminals used on capacitors and the like are easily yielded in removal/reconnection and when that happens they can be resistive, causing them to fail from overheating. Also check the low pressure switch for continuity (again if there is one).
Posted on Jun 04, 2009
My 2002 trane XE 1200 gas &electric unit stopped blowing air
it may be the blower motor not working inside the house check the cap for the motor & the power to the motor
Apr 28, 2014 | Heating & Cooling
Trane xe 900 compressor operates and blower motor stops
You need new compressor (doesn't worth to repair old one). Take a look on amazon: Amazon com Trane air conditioner compressor. I hope this was helpful. cheers
Mar 16, 2013 | Heating & Cooling
Trane xe 1000 - 1/4 fan motor went bad - I replaced it with a used 1/3 from another trane unit - it had same wiring harness etc everything starts, runs, cools -cold air - but only for about 5...
Did the 2 fans have the same rpm. If there is not enough airflow through the outside unit the compressor will shutdown on high discharge pressure. Also make sure the fan blades are positioned right if there is a shroud for them. Did the other motor have a capacitor with it or did you use the 1 from the smaller motor. Sometimes the motor data plate will tell you what size capacitor you need. Let me know what you find.
Aug 24, 2010 | Heating & Cooling
Outdoor fan does not come on
most likely it the the cap that is bad. Is this in heating or cooling mode?
Jun 03, 2010 | Heating & Cooling
I have a Trane XE1200 condensor for which I bought a replacement fan motor, same specs as the original G.E. motor. The original G.E. motor was wired to a dual capacitor, which is also wired to the...
OK, locate the terminals on the capacitor marked "HERM"(Compressor lead), "FAN", and "COM".(common)
HERM and COM remian as they are.
The wire going to "FAN" (usually brown) will be placed on either terminal of the new capacitor. (This is the ((usually brown)) wire comming off of the fan motor.) An additional wire needs to be run from the other terminal of the new capacitor to the "COM" on the old capacior.
What you are doing is bypassing the fan side of the old capacitor but still using the compressor side of the old Cap.
The fan should have a wiring diagram on it to help identify the wires if there is no brown wire. The other two wires will be identified on the wiring diagram as well, but one typically goes to the contactor and the other to the board.
Sep 07, 2009 | Heating & Cooling
Trane XE1200 Fan Motor
Most likely problem with a not-so-old motor is the run capacitor for the fan.
Some units have fan & compressor capacitor combined into one -- others are separate.
The capacitor can be tested with a multi-meter with an MFD setting -- it should read reasonably close to the specs marked on the capacitor.
Charlie
Aug 19, 2009 | Heating & Cooling
Trane XE 1200 ac The outside fan stopped
unless you have a meter youneed to see if the unit is asking the fan to turn on. if so the fan (which i doubt) maybe gone bad or the starting capasitor for the fan... is there anyway of checking the voltage to the fan
Jun 22, 2009 | Heating & Cooling
Carrier 52CE-307-3 Air Conditioner Logo
1,015 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
