Question about Whirlpool Washing Machines
AWZ 541D Machine will not drain water after wash. Error E102/E101? Please help.
  • 6,784 Answers
Check the following to address this issue-- 1. Clogged drain line or water pump Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). 2. Water Pump If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed. Please rate and have a great day:)
Posted on Jun 03, 2009
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Sep 13, 2014 | Electrolux Washing Machines
Error code E102-01 for canon ir7095
E102 - A read error has occurred in relation to the laser scanner unit EEPROM data.
theres a good chance that what is needed here is the laser scanner unit has a Beam Detect mirror and sensor and after time gets coated with foreign particles(dust) cleaning these mirrors/sensors will probably allow the unit to work again- this job should only be undertaken by a qualified service personnel, as more damage than good could be caused. if the laser scanner unit appears clean then iut will need replacing.
Jan 16, 2014 | Canon Office Equipment & Supplies
Hi, I am not able to open the door of my Whirlpool washer dryer AWZ 5140 E after it finishes the cycle. It shows up E13 with ticking noise. There is no water left at this stage and I am able to open the...
E13 is a dispenser error the appliance diagnostic believes the appliance is full of water so won't release the lock first thing to try is the drain filter bottom right hand corner at the front unscrew it clean and refit just be prepared it's likely u will get some water out it when u remove it.
Dec 08, 2013 | Washing Machines
Siemens SI14-44 washing machine is error coding F:18. something wrong with the emptying of the machine.... is the filter blocked? is so where can you clean out the filter?
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
F:18? if this error is for water stuck?
for the automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Washing Machines
417 44152400 21 code reads e63 and machine not draining properly
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Kenmore Front Load Washer
Samsung washing machines water drains continously
The drain hose is too low, you need to lift the height of the drain hose as it is siphoning and won't be able to fill to the required level.
Mar 05, 2012 | Washing Machines
Dynex dx-e101 Driver for Windows 98?
Unfortunately, that card requires Windows 2000 or higher to be used. There are no drivers for Windows 98, 98se, or ME.
Dec 15, 2017 | Dynex DX-E101 Network Adapter
I HAVE BOUGHT SAMSUNGWA80V3 TOP LOADING WASHING MACHINE. I AM GETTING ERROR 5E and WATER IS NOT DRAINED OUT.PLS ADVICE.
this error comes if waste water pipe jammed or blocked
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
check the drain pipe that comes out the back of your machine
please message me back if this does not solve your appliance situation and please remember to rank how this opinion has helped Thanks again
Rick
Nov 09, 2010 | Samsung Washing Machines
LG Washing Machine won't spin, signals that load isn't balanced
Check the drain clean out at the drain pump. If is cloggedm with debris, it will not spin and go off a a long drain error code.
Feb 06, 2010 | Washing Machines
Kenmore washing machine 110.22082 does not drain
you probably looking for a new drain pump ( control board also possible)
Sep 05, 2009 | Washing Machines
Washing Machines Logo
102 people viewed this question
Dan Webster
Dan Webster
Sal De
