Question about DeLonghi DC89TTC Coffee Maker
DeLonghi DC89TTC Series Coffee Maker does not work
I had a blocked filter that cused an overflow - Since the coffemaker was on a serving tray the overflow coffe pooled around the bottom of the coffee maker (DeLonghi DC89TTC Series Coffeemaker) and got into the bottom of the unit. There were no sparks or breaker thrown. The unit shut off and will not make coffee. It clicks on and clicks off within 1 second.
Is this an easy repair or am I better off just buying a new coffe maker
    President:
  • 512 Answers
Your unit is probably wet on inside by bottom heater. Take apart and dry inside of unit. A hair dryer works good for blowing all excess water out and helps dry. If unit is still in warranty go to http://www.delonghi.com Call number they will tell you if unit is still in warranty if so they will replace for shipping costs.
Posted on Jun 17, 2009
Coffee is weak and pucks are being sent out on the wrong side of the coffee maker - 180 degrees away from the puck collection tray.
You need o take mahien apart to service also see the spoil if it loose to move coffee cake in the wrong place
Jun 09, 2015 | DeLonghi Magnifica Coffee Makers &...
If i try to make more than 6 or 8 cups in my 10 cup bunn coffemaker. The coffee grounds overflow . This is a new coffee maker and we find a mess almost every time we make a pot. We have alwats used bunn...
This can occur with the use of finer ground coffee or use of soft water, filtered water, or bottled water. If you will call 800-352-2866 with the model and date code, we can send you a flow restrictor sprayhead which will alleviate this problem.
Jun 20, 2010 | Bunn 10 Cup Home Coffee Brewer
I have a krups coffemaker model 264A with a broken filter basket. Are these filters still available for purchase?
I have the same problem for the same Krups model 264A duo coffee maker. Does anyone know where I can buy a filter basket for this now-discontinued coffee maker?
Feb 15, 2010 | Krups Coffee Makers & Espresso Machines
Does DeLonghi make a thermal carafe for coffemaker model number DC312T ? If so, where can we get one?
Can't use a thermal carafe with this unit even if one were available. The thermal carafe doesn't require a heating unit under it while sitting on the coffee maker. It keeps the coffee hot by it's built in insulation in the pot.
Just buy a regular insulated pitcher at most any appliance outlet (WalMart, Target, etc.) and pour it in it. Just shut off the coffee maker then.
Dec 27, 2009 | DeLonghi DC312T 14-Cup Coffee Maker
Coffee is leaking onto burner and spilling onto counter, yet the carafe is not leaking. The problem seems to be coming from the drip
Does the coffee seem to be overflowing the coffe maker and the running down? If so the valve where the filter is placed is not working properly. When you place the coffee pot it actuates a small arm which inurn opens a valve at the base of the filter unit. If this is the case remove the unit and correct this unit. In speaking from past experience I know this happen to our coffe maker while the unit was apart being cleaned; it was just a matter of proper reassemble.
I hope this may have helped,
Tom
Sep 07, 2009 | DeLonghi Coffee Makers & Espresso Machines
I lost the mesh filter on my DeLonghi Caffe Elite coffee maker. How can I obtain a replacement?
Since nobody could tell me where I could purchase a replacement mesh screen folter, I now use 2 paper filters and that seems to work reasonably well.
Apr 18, 2009 | DeLonghi Caffe Elite DC76T Coffee Maker
I believe is need a new gasket for where the filter cup meets the espresso maker. I am not getting the same pressure when making coffee. It is a Krups 871 model
I have a #872 model. It is very similar to the #871.
Where the gasket is there is a small metal filter too, attached by a screw.
UNPLUG your coffemaker!!!
If you unscrew the filter and remove it with the gasket most likely you are going to find the other side of it clogged by coffee. Wash it off and wash the gasket well too with dishwashing soap. Rinse them off well.
You should try to clean off the coffemaker part to where the gasket lays. Usually it is full of burnt of coffee.
If there is no other problem with your coffemaker this should solve your problem.
Sep 28, 2008 | Krups Bravo Plus 872 Espresso Machine
Coffee Make Just Stopped Working -- Any guidance appreciated
COFFEE MAKERS NOW A DAYS ARE SO CHEAP TO BUY I REPLACE MINE EVERY FEW YEARS , GO OUT AND GET YOURSELF A COFFEMAKER ,
" BEST PART ABOUT WAKING UP, folgers in YOUR CUP"
May 27, 2008 | DeLonghi DCU61 Coffee Maker
Coffee Makers & Espresso Machines Logo
165 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
