Question about Karcher 2500 PSI Pressure Washer
Pressure Washer trouble The Engine Won't Turn Over. What's Wrong?
I have the same problem, i don't use my for 2 years.
I Never had any problems, brand new to, Karcher 2,500 PSI power washer with a 5HP Honda engine...
The Engine Won't Turn Over. What's Wrong?....
  • 40 Answers
Well for starters if you let it sit all winter you the pump probably froz up and you might be able to get it un jamed by pouring in oil (any kind) in the hose inlet and let sit one night the try starting
Posted on Jun 03, 2009
My 1998 mercury sable wont star what can be wrong.
several things can be wrong. does it have fuel pressure does it have spark at the plugs. what condition is the battery. you don`t say what type of problem your having, like will the engine not turn over, it does turn over but won`t start up, it starts up then dies right away. your very vague as to what your after with minimum info supplied.
Oct 11, 2014 | Cars & Trucks
1998 Honda Accord Won't Start
Park neutral safety switch maybe be the reason for the no crank ! Try putting the vehicle in park ,then try to crank the engine . Testing the electrical circuit is the best way to trouble shoot this problem , along with do a voltage drop test on the starter circuit ! This will test the battery cables an connections .
Starter Voltage Drop
How to voltage drop test starter motor circuit
Does it have a manual or automatic transmission ? Manual ? clutch switch . Looking at a wiring diagram I also see a starter cut relay !
http://www.bbbind.com/free_tsb.html Free wiring diagrams . Enter vehicle info. year , make , model and engine size . Under system click engine , under subsystem click starting . Then click the search button , then click the blue link ! Check the starter cut relay also . Videos on youtube showing how to test a relay controlled circuit !
May 29, 2017 | 1998 Honda Accord
1994 Honda Prelude si starting problems
Your starter motor is either not getting power or in need of replacement. Otherwise, there is nothing wrong with your car.
Also check your battery connections for no corrosion there as well as by the starter motor. Low voltage circuits in a car are extremely vulnerable to poor contact issues.
Mar 29, 2017 | Honda Prelude Cars & Trucks
Pressure washer is pulsating when powered on
it just the presure building back up ,it will last years doing this,i would not worrie as replacing the presure pump will only be a temp fix and it will do it again ,most washes do this after a year or lots of use.
Dec 31, 2009 | Karcher 1750 psi Electric Pressure Washer
I have a Karcher 2,600 PSI 2.3 GPM Gas Pressure Washer G 2600 VHR that I have used once last summer. I have stored the PW in my basement with no fuel in the gas tank. The PW was never exposed to freezing...
Hi I have a similar pressure washer from Kartcher and the same scenario as yours I have owned it for about 2 years and noticed that it was getting harder and harder to start with each time I use it which is months. If your pw has a honda engine on it the likely culprit may be the carbuerator. The main and pilot jets may get clogged up with gunk from dired up gasoline. To see if you have a fuel problem spray a shot of starter fluid into the carberator with the choke open, then close it and try to start. If it runs for about a second and dies, then the carbuerator is at fault and you are not getting fuel into your motor and all you're doing is working out your arm.
Jul 05, 2009 | Karcher G 2600 VH Gas Pressure Washer
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
Engine won't turn over
Pull the spark plug back out and try to turn the engine over. If it doesn't move then the engine is probable seized. Was the engine oil res. full of oil and was the color acceptable.
Apr 28, 2009 | Karcher 2500 PSI Pressure Washer
HE3 washer Control malfunction?
Bad control board is most likely problem.
Dec 09, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Karcher 2500 PSI Pressure Washer Logo
1,029 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
