Question about GE Spectra JBP78 Electric Kitchen Range
Ge range hi my ge spectra has the dual front burner. this one burner does not work. unfortunately, i let a friend look at it. the ceramic ring is broken-don't know if it was broken while looking or before. also, the crimp wire that makes the circles was cut at the connection-this was done by the friend instead of sliding off the connectors. it is just cut on one connection. he said when i set the new part it will come with all attachments....is this fixable or junk? the knob to this burner was stripped out. the stove was in my rental house, and i'd like to be able to fix it if possible. thanks for any help.
If the ceramic ring you're talking about is around the far outside of the element, then it being broken isn't a big deal (as long as pieces aren't missing). Its just an insulator.
If the knob is stripped, how are you turning the burner on? Are you sure the problem is the element and not the knob?
Either way, since your "friend" cut the wire, the element is not going to work properly. The crimp connections are designed to be removed and replaced, and the element is not going to come with any additional parts. Go to Radio Shack or an auto parts store and get a replacement crimp connector. You'll have to strip and recrimp a connector on the wire your friend cut. The wire may not be long enough now, though, so you'll have to twist the element while installing it so that the wire will reach. This should be fine as there's plenty of room to spin the element around.
Posted on Nov 20, 2007
GE Spectra Dual Burner not working.
the burner is faulty
replace just the upper part of the brner
or try to clean it
yourself
Sep 16, 2008 | GE Spectra JBP78 Electric Kitchen Range
Spectra GE model JBP64W0B4WW stove top burner stopped working
Which element is it? Try to switch the infinite switch from another element. This will tell you if it is the element or the switch problem.
Apr 06, 2013 | GE Spectra JBP78 Electric Kitchen Range
Dual top burner will only heat up on high.It is only the large ring burner GE JBP79
Does it go straight to full heat even though it is on the low setting. If this is the case the hotplate controller is faulty and requires replacement.
Feb 24, 2011 | GE Spectra JBP78 Electric Kitchen Range
Small burner of dual surface(right front) stopped working.
Does yours have the (small large burner switch)? If so, try switching it back and forth. It could be defective or your small burner element is bad.
Mar 11, 2009 | GE Spectra JBP78 Electric Kitchen Range
JBP78W electric smoothtop small burner in dual burner not working
you call a repairman, Like I did , expect to pay 150.00 or more as the small burner and large one are in the same ceramic holder
Oct 17, 2017 | GE Spectra JBP78 Electric Kitchen Range
GE Spectra JBP64BB front right large burner won't work anymore
how are you the GE Spectra JBP78 Electric... Problem: Subject: the proble is that i had a shortge of power and i have the ""lockdoor"" showing
Jul 29, 2008 | GE Spectra JBP78 Electric Kitchen Range
GE Spectra - burner pops & blows breaker
Either the burner has gone bad or the limiter on the burner.
Jul 11, 2008 | GE Spectra JBP78 Electric Kitchen Range
GE Spectra JBP78 Electric Kitchen Range Logo
104 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
