Question about GE WBSR3140DW Top Load Washer
Frustrated with washer
I have no problem washing on a low cycle BUT as soon as I wash on a full cycle load the water just keeps running and running and it is like
it is not triggering some kind of censor,but as soon as I switch it on the low cycle it washes
  • Anonymous Nov 09, 2007
    tHE W
  • 64 Answers
Sounds like the water level sensor is faulty on the 'high level' setting. If you disconnect the sensor & blow & suck up the small pipe, you should hear 2, or maybe 3 clicks as the internal switces operate, if you dont hear the clicks, this could be the problem
Posted on Oct 24, 2007
Can you adjust the water level if you want more water for your wash cycle?
it may be possible if the water level pressure sensor has an adjustment for the pressure setting
or you could simply select full wash each time
Jan 07, 2016 | Maytag Centennial EcoConserve Top Load...
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
During the spin cycles in the wash the machine makes a loud whining noise while spinning? As soon as the cycle is finished the problem goes away. Is this a faulty belt or what. Please help.
Either the belt or you transmission could be slipping and it making the belt work harder on a full load. Try running the spin cycle without water to see if you hear it. If you do then it is the belt, but if you only hear with water then it is your transmission.
Apr 18, 2011 | Frigidaire FEX831CS Top Load Stacked...
Face Clothes and Towels are smelling bad after being washed and dried in my Kenmore HE3 washer and dryer. Have tried running an empty cycle with bleach only, washed small loads with hot water, pre-wash and...
Try running an empty heavy duty wash cycle with a pint of vinegar added to the water, run wash cycle for two or three minutes then turn the machine off for thirty minutes then restart and let finish the full wash cycle
Aug 02, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washing machine won't complete cycle
If it is a hot and cold fill washer, yes, then it could be a hot water problem related to the valve, or the water supply., if it is cold fill only, then the problem is elsewhere.
Pleas rate my solutikon.
Thanks.
May 13, 2009 | Whirlpool AWM5125/1 Front Load Washer
Water keeps draining LG WF-561SPP top loader
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Apr 02, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Washing machine
full of sudsy soap after cycle complete, no water ???sounds as if your using the wrong detergent, youll NEED to use an HE detergent (low sudsing)specifically designed for use with front loading washers
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
LG washing machine problem
I had the same problem with my LG front load. The second repairman fixed the problem. The water lines going into the machine were clogged with sediment (probably because I have well water). This caused the cups to remain full of water because the water pressure was so low the siphons were not working as they should to empty the cups. This also caused the wash cycles to be extremely long (sometimes 2 hours) because it took so long for the water to enter the machine for the wash & rinse cycles. Since the lines have been cleaned it works fine.
Jan 08, 2008 | Washing Machines
GE WBSR3140DW Top Load Washer Logo
32 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
