Question about Desa International 100089 06 Electric Chain Saw
I have a TroyBilt electric chain saw and need geardrive
I have a TroyBilt electric chain saw and the plastic gear drive is worn out a common problem so I've found out, need a new one and unable to find a supplier,the model number is TB 4516
  • dontbother10
    dontbother10 May 11, 2010
    We need the complete make, model, and serial numbers from the manufacturer's tag.
    President:
  • 2,220 Answers
Your manual downloads from MTDProducts.com. This is the parts outlet for MTD. Troy-built is listed here:
http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_BuyMTDOnline_10101_19502_-1
I clicked"
PARTS CATALOG "Troy-Bilt" enter
FIND YOUR PART "OPTION 1:" click the wrench
Model Name/Number: I entered "tb4516" and your parts list appears.
Your manual lists this phone number 1 (800) 520-5520. Please try them if the above isn't satisfactory.
GL
Lou
Posted on Sep 16, 2009
I have the same chainsaw, but with a burned out motor. The gear drive appears to be in great shape. I'd like to get rid of the whole chainsaw for parts if possible. Let me know if you're interested or have already found a replacement.
Posted on Mar 15, 2010
Saw is making noise like the bearings is going when I let of the trigger of the saw, how can I fix this peoblem
Best choice Lubrication of armature gear > ( renolit paragon ep 2 or amblygon ta15) if bearings are have to much looseness replace them. armature/geardrive can very fast become worn if too long was used without timely the use of some lubrication.
May 24, 2016 | Skil Shd77m 15 Amp 7-1/4-inch Mag Worm...
Have a problem with my electrical Kraftsman chain saw, the engine is running and the chain is rotating, but when I put it against the tree for cut, the chain will stop rotate bot the engine is still...
The main drive gear is slipping. This is caused by etiher worn teeth or worn bearings. If you pass the model number I can show you a diagram of where to look and what part or parts that have most likely failed. The drive gear is the weakest link but the motor can be shifting in the housing away from the drive gear. It only takes a bit less than 1/8 inch side play. The model number will be similar to this 358.341160
Most likely it is item 26 of this diagram:
http://c.searspartsdirect.com/lis_png/PLDM/P0101241-00001.png
This example is for model 358.381160
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Chainsaw-Parts/Model-358341160/0247/1503210/P0101241/00001?blt=06&prst=&shdMod=
Thanks for choosing FixYa, Kelly
Sep 13, 2011 | Craftsman 16" Electric Chainsaw Chain Saw...
In the wheel gear adjuster for chain does not thighen chain when turning wheel like little gears are not matching up, what would be wrong?
The three hundred series saws have side adjust consisting of a small assembly, if the gears are worn it will require replacment, the hobby saw ( 235/236/240 ) had a plastic gear on the early models in the side cover, this has now been replaced with a metal gear, the semi pro saw has the assembly in the crankcase, this will require removing the clutch sprocket and bar plate to gain acsess to it.
Jan 22, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chain stops when it touchs log
A gas engined saw has a clutch that can slip if overly oiled internally, but electric saws don't use a clutch. Most however, have a safety disconnect to the drive sprocket that shears or otherwise removes power to the chain while the motor runs. The worst problem can be a broken gear within the gearbox and requires dis-assembly to discover. Many modern saws use plastic gears in place of metal ones and are prone to failure. The fact that the chain turns when not under load would seem to eliminate the gearbox, but don't discount that until proven. Hope this helps!
Jun 23, 2010 | McCulloch 10" Electric Pole / Chain Saw
Chain comes off mcculloch electramac em250 chain saw
Adjust the chain until you can pull on it and it will come away from the bar but will not hang from the bar. If that does not solve your problem then the chain or drive gear is worn out. If the oiler is not working it is for sure worn out.
Apr 25, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Ryobi ECW 1836 electric chain saw. No drive
Check to be sure your chain brake is in the OFF position Pulled back towards the operator
Apr 01, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Remington chain saw, electric: jammed and now the
I went here:
Remington.com
http://www.desaparts.com/index.htm
  • Typed "M30016US" into the "Model #:" window, then clicked search.
  • Click the M30016US - Remington Electric Chain Saw "View Model" link.
  • Click "View Illustrated Parts Breakdown" think you want item 18, 113004-01, Internal Gear
  • Click the 113004-01 - USE REPLACEMENT PART # 122513-01 "View Part" link.
Results follow:
Part #: 122513-01 Price: $24.00
Description: KIT, INTERNAL GEAR (MOD) 747 B/O
If this is what you need I suggest you order it soon.
RemingtonPower has stopped production and replacement pars are almost exhausted. Sooner or later a part you need will be NLA. HTH
Lou
Nov 10, 2009 | Remington M30016US 16" 3.0 Peak Hp Modular...
Remington Electric Chain Saw, Model 106890-02 I need a gear replacement for the plastic gear betwen the drive gear and the gear which drives the chain.
Here is a link to the model 106890-02... http://12.153.20.74/manuals/107052-01A.pdf, I would also suggest you contact the parts department at 800-446-1446. They should be able to help you.
Mar 15, 2009 | Remington Garden
Worn plastic drive gear
Here is a link to the owner's manual... http://12.153.20.74/manuals/107705-01V.PDF. The part you need is 107713-01. You can order it online at www.masterparts.net or by calling 800-446-1446. They should have it in stock. I hope this helps.
Oct 16, 2008 | Desa International 100089 06 Electric...
Desa International 100089 06 Electric Chain Saw Logo
685 people viewed this question
Top Desa International Garden Experts
Roland W VanLue
Roland W VanLue
ray gallant
Tim Whalen
Are you a Desa International Garden Expert? Answer questions, earn points and help others
