Question about Frigidaire Dishwashers
Dishwasher runs several hours
Model FDB125RHS0 dishwasher runs several hours. Seems to be okay the first 20minutes and sounds like the dial is moving therefore the timer was turning
  • 6,784 Answers
OK, that several hour wash cycle seems to be very abnormal and, the only way this can happen is if the timer control mechanism is damaged. this is referred to as a Overrun error. simply replacing the timer will fix this issue.
Posted on Jun 03, 2009
Dishwasher runs too long
Good Morning Tessa,
I understand that your Frigidaire dishwasher, model# FDB700BFC, is running too long. I also see that it seems to be getting stuck on one particular cycle and runs continuously for hours even though the water is hot. It sounds like there is possibly a miscommunication between the different boards inside your appliance. I please ask that you try resetting your dishwasher, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Once power is restored, try running any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire FDB700BFC Built-in Dishwasher
Candy Dishwasher leaks from front door during cycle.
Sounds like your gasket has a problem or --- are you using HE soap as you should? Maybe too many suds is causing the problem
Jan 08, 2014 | Candy Dishwashers
DDW1802W ran fine yesterday. Panel light os, no start. Door seems to latch okay. It's not an overflow switch issue. No burnt smell.
dishwasher wont turn on. power is ok. when you turn the dial with the power switch on it clicks motor turn on pumps do not turn on wont fill or empty power light does nnot light up latch seems to be fastening proper is there a reset switch
Apr 09, 2011 | Danby 17 in. DDW1802W Designer Series...
1)My Candy DFI 50 is not washing properly, it leaves residue on the pots. 2)The programme controller on my DFI 50 seems to be sticking. Sometimes the dial doesn't move at all or takes 'hours' to run a...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Aug 09, 2010 | Candy DFI Plan Built-In Dishwasher
Danby Dishwasher stuck in drain cycle after wrong soap use
There might be water in the overflow sensor. I unloaded the dishwasher and lifted the front so the dishwasher rested on its back. There's a narrow gray tube that runs down from the bottom right of the door. The tube runs into a white piece of plastic with some wires coming out of it. There is a rubber plug that covers a nipple on the plastic. Pull the rubber plug off. Mine was quite tight. Tip the dishwasher back onto its casters to drain the water from the overflow. Check to see if the dishwasher functions normally, then put the rubber plug back on.
Dec 10, 2009 | Danby DDW1805W Designer Series...
Dishwasher stalls
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
May 31, 2009 | Bosch SHU4006 Dishwasher
Dishwasher stalls
SOUNDS TO ME YOUR CONTROL MODULE IS NOT WORKING CORRECTLY
Apr 07, 2009 | Bosch SHU4006 Dishwasher
DISHWASHER
this is a sign of a defective timer mechanism. replacing the timer will fix this issue. Replace the timer/control model asap.
Nov 03, 2008 | Roper 24 in. RUD3000 Built-in Dishwasher
Indeset d63 dishwasher
The heater is faulty Regards Engineer
Aug 17, 2007 | Baumatic 24 in. BFD60SS Free-standing...
Dishwashers Logo
274 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
