Question about Sharp EL-1801P Calculator
Calculator problem Can you please tell me how to change the time and date on my calculator?
  • destiny249 Oct 24, 2007
    this sharp calulator does not have a menu and setting button. The buttons are: cost, sell, mgn, t/-, avg, gt, tax+, tax-
  • Anonymous Nov 05, 2007
    HERE IS THE ANSWER TO TIME & DATE
    Problem Solver:
  • 6 Answers
Look for the menu then setting and look for time!!!!
Posted on Oct 24, 2007
Think you so much i spent like 30mins in the computer and noting would ever tell me how to do it and when i did i could not see it it so think you very much :)
Posted on Oct 31, 2008
5 Suggested Answers
  • 3 Answers
SOURCE: cant change time/date
Posted on Jan 29, 2008
SOURCE: need to change the time on calculator
To set up date, time, conversion rate, and tax/discount
rate, place the switch at the "RATE SET" position.
Date:
Enter in the order of month, day and year, then press date/time button
to complete the entry.
Use ▪ to separate month, day, and year EXAMPLE 3▪13▪2009.
When (date/time) button is pressed, the number entered is evaluated
and displayed as “date”
Time:
Enter in the order of hour, minutes, then press date/time button to
complete the entry.
(There is no entry available for the seconds value. The
clock starts at zero second.)
Use to separate hour and minute values EXAMPLE 8▪15
When is date/time button is pressed, the number entered is evaluated
and displayed as “time
When settings are complete place the switch back to GT
Posted on Mar 13, 2009
  • 207 Answers
SOURCE: I need to change the time on my Sharp EL-1750PIII calculator
You can access the .pdf manual for your particular calculator here:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Page 1 for how to set date/time:
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as “date” if the
value is within the following range; “Error” is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Posted on Apr 27, 2009
twitchyguy
  • 12 Answers
SOURCE: change date and time
Shearch for your device on retrevo.com and see if they have the manual. You can download it as a pdf for free.
Posted on Jan 11, 2010
I need instructions to change the date & time please
Change the date & time on what make and model calculator?
Oct 30, 2013 | Office Equipment & Supplies
The date will not set unless I use the default date. The time is set but the date will not. is there a solution to this?
Eureka! I was having this problem too! try using european format - day then month... when at default date you can't tell what format it is in so when trying to program it wont take an incorrect date (today is the 19th and I was trying to put that in the month field, invalid date so no dice) once you enter it you can change the format to whatever you prefer...
Sep 14, 2011 | Canon P200-DHIII Calculator
Canon P200 DHIII calculator needs to be changed the date. Can you tell me how?
Below are the steps to assist you in
setting the Date and Time on your calculator.
NOTE: The "Time Set", "AM/PM", "12/24" and "Format" associated keys are
on the faceplate above the respective key. Position the calculator so
that you can look directly over the keypad to see the notations.
Setting the date:
1. Press the CALENDAR/CLOCK Key. The default date will appear.
2. Hold the TIME SET key down for 3 seconds or until you see the first
digit begin to blink in the display.
3. Input the correct date.
4. Firmly press and release the TIME SET key. The first digit should
stop blinking and the date is then set.
Setting the time:
1. Press the CALENDAR/CLOCK key. The default time will appear.
NOTE: The seconds will disappear.
3. Input the correct time. If you need to adjust to AM or PM, press
the AM/PM accordingly.
stop blinking and the time is then set. The seconds will again be
displayed.
Follow by pressing the CLEAR key to return to the calculator mode. To
return to either the TIME or DATE, press the CALENDAR/CLOCK key to
toggle between them.
Jan 22, 2010 | Canon P200-DHIII Calculator
Need to change the time on calculator
Date:
Time:
complete the entry.
Mar 11, 2009 | Sharp EL-1197PIII Calculator
CASIO-DR_T120
Hit time then hit set hold down for about 2 seconds (% key) then change the time hour, minutes it will change back to date but if you just hit CA button the time will be set
Sep 23, 2008 | Casio DR-T120 Calculator
EL 1801V - how to set time/date?
To change the date, enter the date in MM.DD.YY format, pressing the decimal key between the month and day (will show as a decimal on the display) and the day and year (will show as a dash on the display). Then, press the Time/Date key (the one that looks like a clock and a calendar). The new date will show on the display. Note that if the month is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. To change the time, enter the time in 24-hour HH.MM format, pressing the decimal key between the hour and minute. Then, press the Time/Date key. The new time will show on the display. Note that if the hour is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. Hope this helps! :)
Sep 02, 2008 | Sharp EL-1801P Calculator
Change time & date on the victor 1530-5 adding machine
I recently solved this issue with my calculator
Press and hold the time key when the date is dispalyed. When the display flashes enter the date as a six digit date (example 110608 for November 6, 2008) Time needs to be entered in military time when changing time.
Aug 15, 2008 | Office Equipment & Supplies
Ho w to set the date and time
Go to the link below. You need adobe acrobat to read. THere is a section in the manual called "Adjust Date & Time"
For Date:
Put Calculator on RATE SET
Press Time/date key: enter the date using a decimal between the month, day and year (all 4 digits) please the date/time button. It should reset. (Exmple: 01.16.2009)
For time:
Leave Calculator on RATE SET
Press Time/Date key until time shows up. just like date, press the hour then the decimal then the minute. (Example if the time is 10:15 you enter 10 . 15) Press the Time/Date Key and the time is set.
This link is the manual:
Jun 04, 2008 | Sharp EL-1750PIII Calculator
Canon P100-DH Calculator manual
How to change the roller ribbon on my Canon P100-dh calculator?
Jan 10, 2008 | Canon P100-DHII Calculator
Change time on calculator
I have a model DR-T120 maybe it works the same way.
press
CA
TIME
% (hold for about 2 sec)
"enter date and time"
Note( any time during setting procedure you can press = to cycle date format mm-dd-yyy, dd-mm-yyy, yyy-mm-dd)
TIME
Hope this Helps.
Rick
Nov 21, 2007 | Casio DR-T220 Calculator
Sharp EL-1801P Calculator Logo
117 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
