Question about Casio FX-115ES Scientific Calculator
I cant get the calculator away from fractuons
  • Casio Master
  • 7,993 Answers
Use the [S<-->D] key to switch back and forth between the two format.
If you do not want any of the new stuff [MODE][LineIO][ENTER]. Your calculator will do as you are familiar with.
Hope it helps
Posted on Sep 07, 2009
Remove f(x)
Change the calculation mode to COMP.
Mar 06, 2014 | Casio fx-300ES Calculator
Cant get "fix" off calculator
This is indicating that the calculator is set to a fixed decimal notation. You can change the notation to scientific or engineering, but in those cases you'll see either "SCI" or "ENG" on the display in place of the "FIX".
You can also specify a floating notation by pressing 2nd [FLO], in which case none of the annunciators light up.
Sep 19, 2011 | Texas Instruments TI-30XA Calculator
On my TI 84 the screen went black, I can see the slight outlines of the numbers behind it but it wont go away. When I turn off the calculator it goes away. How do i fix it?
if you try to reduce the light on the screen and it dd not help
it could be a problem with the screen
if you want to fix the Calculator let me know
ecrdn@yahoo.com
Jack
Oct 12, 2010 | Texas Instruments TI-83 Plus Calculator
I cant get the screen to go away from f(x)= and i want the answer to be converted to a decimal answer instead of in fraction form
I believe your calculator is set up to do TABLE computations. In these computations you enter the function for which you want a table generated.
Press [SHIFT][9] to clear/reset the calculator. You should find a CLR marking on calculator near the 9 key.
You can also press [MODE] button and select [COMP], which is the general computational mode.
To have the calculator display all results in decimal format
Press [SHIFT][MODE] to enter (SETUP) and select [2:LineIO]
Aug 20, 2010 | Casio fx-300ES Calculator
I have a black screen mon my TI=83 that I cant make go away
Salut,
Chassez le naturel il revient au galop.
Si ton écran est noir, tu peux réduire le contrast.
Appuie sur la touche [2nd] puis libère-la.
Appuie sur la touche [Flèche vers le bas] et maintiens la pression jusqu'à ce que l'écran s'éclaircisse à ton goût.
Appuie sur la touche [CLEAR] pour effacer l'affichage.
Press [2nd] and release it.
Press and HOLD [DownArrow] till screen lightens enough.
Press [CLEAR] to clear the screen.
Hope it helps.
Oct 29, 2009 | Texas Instruments TI-83 Plus Silver...
Screen damage
they cant. The pixel is damaged.
Oct 15, 2009 | Texas Instruments TI-84 Plus Calculator
I cant find the EXP or ee button on my casio
the EXP button is the one that says 'x10' next to the 'Ans' key at the bottom.
May 01, 2009 | Casio fx-300ES Calculator
Cant find a button
You didn't specify the make and model of calculator, but here goes...
It may be marked +/-, CHS, or (-). If that doesn't help, please tell us what calculator you're trying to use.
Feb 22, 2009 | Office Equipment & Supplies
I only have half a screen! TI-84plus
try resetting the calculator. It might be a drawing.
hit 2nd
then +
then 7
then 1
then 2
Nov 06, 2008 | Texas Instruments TI-84 Plus Silver...
Casio FX-115ES Scientific Calculator Logo
50 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
