Question about Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Dell Dimension 8400 Bottom DVD Drive will not open
The DVD drive will simply not open. I tried to Re-install the drives and there are apparently 3 different disk drives or something. I brought up the properties menu from the my computer screen and it says that the drives are working fine, but it will not open. i have no idea what I am doing and would really like to open this drive!
    Scholar:
  • 52 Answers
Well in most PC related optical drives, there is a very small opening on the front of the drive, who gives access to the opening mecanism. You can use one end of a small paperclip to reach it. (In case you have a CD in there you want) Now about it working the usual way, there isnt much your can do, maybe somthing related to it's power, but again, if somthing is broken... unless it's still in waranty Good luck!
Posted on Jun 03, 2009
Pata slave drive not found in bios a05 of dell dimension 8400 but found in windows and linux os's
Hi
Have you tried swapping the pata drives - eg master to slave and vice versa ?. I have found that if the drives are not from the same manufacturer, quite often, you cannot get both drives to work. Seagate and WD normally are O.K., but some of the older Fujitsu ones just knock out any other drives on the same 40/80 way cable.
Mar 17, 2017 | Dell Dimension 8400 PC Desktop
Dell 8400 Boots to Black Error Screen in XP States to reinstall System 32
This might be caused by hard-drive failure. You should run hard drive test from BIOS to make sure hard drive is ok. You can access BIOS by pressing F2 during start up, from there start hard disk self test and wait for it to complete.
If hard drive is ok after test, insert in your original Windows installation media and reinstall OS.
Oct 02, 2012 | Dell Dimension 8400 PC Desktop
Won't see the dvd drive I installed
do not use slave or master settings. use the alternative, it should work,
May 15, 2010 | Dell Dimension 8400 PC Desktop
Sonic, Dell Dimension 8400, Philips DVD +- RW burner
are you copying ,copy writed material?then you need dvd descripter.
Jun 14, 2009 | Dell Dimension 8400 PC Desktop
I have a Dell Dimension 8400 that I just installed a new sata hard drive on. I've tried many times but I can't get 'windows XP' installed. It's a brand new hard drive and I formatted it when I tried to...
Is i giving any errors when you try to install? You may need to download the Sata controller Drivers from Dell and when prompted choose the F6 option and install them then.
Hope this helps,
David
Mar 11, 2009 | Dell Dimension 8400 PC Desktop
DVD drive bay
yes you should be able to play CD on the DVD reader.
Dimension 2400 have drive slide mounted on the side of the hard drive, cd drive and floppy. they are different for each device. you need the 2 side mount for the dvd. in order to mount them in the Dell.
the drive is inserted from the inside of the box toward the front. The front panel will prevent the device from pop out.
yes, 3 party DVD, CD drive will be shorter and fater that what Dell porvide, but it will work, al long as the opening is accessable.
get the HP DVD driver.
Nov 04, 2008 | Dell Dimension 2400 PC Desktop
Install 2nd Hard Drive in a Dell Dimension 8400 Computer
all u do is make your new hard drive the master by setting the correct jumper for it the manual will tell u more. then make the old drive a slave. install yr opreating system it should be installed in drive c: thats the master when done, u do yr normal copy and paste to transfer your files from old drive to new drive.
xerick
May 22, 2008 | Dell Dimension 8400 PC Desktop
Dell (313-1220) CD-RW/DVD-ROM Combo Drive Logo
509 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
