Question about Sony Playstation 3 (PS3) Console
My triton martinique electric shower low pressure light comes on and the water goes cold but there is nothing wrong with the pressure
  • 3 Answers
I had a brand new Triton Rapide 3 with this issue, we had good water pressure but the light on the front would keep coming on.
I found there was a micro switch located at the front almost dead center of the shower, couldn't miss it when you removed the cover. A plastic arm below this switch is raised when the water pressure increases tripping this switch and allowing the heater to come on.
I found two things wrong with this, one this plastic leaver was thin and bent easily and secondly the switch did no line up overly well with the lever. Easily fixed, I cut an inch off the end of a zip tie or panduit strap, and super-glued it to the top of the lever (not the switch as the glue will probably ruin the micro switch.) 5 minute job later and with the shower back together it works beautifully. My wife will be happy, you wouldn't believe the torrid of curses I got this morning having only replaced the old unit last night.
Probably don't need to say this but, make sure you isolate the power before removing the cover.
Posted on Jun 30, 2009
  • ian991 Dec 29, 2010
    Thanks for your help , You were spot on , easy fix
  • Lb1875 May 26, 2012
    Brilliant fix,
    As above my dearest wife lost the plot at the low pressure symptom, as advised above, bit cable tie, bit glue ,2 mins max, ran shower with washing machine on and still no low pressure :)
    Genius :)
Replace the blue 100nf capacitor on the pcb board near the top. Mine was down to 18nf. New cap ( change out of 50p ) at Maplins or RSComponents cured the problem.
Posted on Sep 05, 2009
I had the same problem with a brand new Triton Martinique. Fitted by a plumber, the water pressure checked out at just under 3bar. The minimum for the shower is stated as 1.5 bar. Rang Triton, stroppy woman told me to check the pressure where the water enters the shower. Despite explaining that we were getting the minimum flow (11 litres min) out of the shower hose with the head off, she would not accept that the shower had a fault. After reading this blog, I checked the micro switch and found the plunger that is supposed to rise to activate very stiff. Having moved it up and down a few times, I re assembled the shower and tested it. It worked perfectly. Turning a tap on to reduce the pressure, the safety device worked, turning the tap off produced sufficient pressure to operate the shower again. It's a shame Triton couldn't have been more helpful rather than just going on the defensive!
Posted on Aug 19, 2010
  • binash Dec 22, 2010
    Hi, I'm having trouble with no water at all passing through my marinique.
    there is enough water pressure getting to the unit but it keeps cutting out with the low pressure light coming on I have cleaned the filters and checked all connections but still cant get it to work any help would be much appreciated.
2 Suggested Answers
shadowarrior
  • 43 Answers
SOURCE: My triton martinique electric shower low pressure light comes on
how on earth is this related to gaming consoles or PS3 ??
Please post under correct sections next time.
Anyways, it looks like a common problem for the Triton Shower, and it might cost you some $90 to fix it.
http://www.comparestoreprices.co.uk/showers/triton-martinique-10-5kw.asp
Posted on Sep 07, 2009
Triton martinique shower runs cold .Selector light goes from hot to cold
forums.moneysavingexpert.com/showthread.p...
Jun 30, 2014 | Home
Triton showers after runs hot then after a while goes cold
Is it possible that you don't have enough water pressure, electric shower heater elements will cut out if the water pressure gets too low, try increasing the water flow.
Apr 13, 2014 | Kitchen Appliances - Others
Triton t300si shower low pressure problem
there is a fine inlet filter on the plastic pipe,remove and wash under tap pressure
Feb 26, 2013 | Home
My triton shower won't turn off and has no hot water
Your supply pressure is too high for the unit, it is too much for the solenoid to shut off, you need to put a pressure limiting valve inline.
Mar 10, 2012 | Home
Installed a new shower water will not heat up
you need to find out how many gallons per minute your shower is ? and what the old one was at then that will tell you if you need a pump.
Mar 27, 2010 | Plumbing
My triton T100xr shower is flashing low pressure
my triton t100xr shower will work for a while then the low pressure light comes on and the shower shuts down not restarting for quite some time, any suggestions please
Nov 03, 2009 | Kitchen Appliances - Others
Sep 07, 2009 | Sony Playstation 3 (PS3) Console
Triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
Dec 01, 2008 | Home
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Sony Playstation 3 (PS3) Console Logo
2,501 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
