Question about Acomdata (HD320UFAPE5-72) (HD320UFAPE572) 320 GB Hard Drive
Acomdata 320GB drive is not recognized
Red drive light comes on, device connects, but is not recognized by any system I've attached it to. I've tried multiple USB ports, rebooted, checked device manager (not listed as drive, but is listed as unknown device in USB section), etc. NO GO. Any ideas?
  • 696 Answers
If the light is on it only confirms that you have power, if it doesn't work on other ports or another computer then it's likely the circuitry of either the drive or shell is damaged, take it to a computer store and have the techs swap it into a new shell(about $40). Then have them test it, if it works you're done, if not then it is the circuitry in the drive itself that is damaged and you will need to send it for data recovery if you want the files back.
Send me an update once you have tried this suggestions and let me know how you made out. If you require the help of a pro for the final steps, reply with your country and region and I will locate a reputable facility to assist you further.
Chris
Posted on Jun 04, 2009
My acomdata hd appears on my desktop then disappears. A red light comes on in the drive
make sure the lead/s that attach to your hard drive are securely seated
if your computer came with a motherboard disc the drivers could be on it
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
Apr 13, 2012 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Booted up my computer this am and the red light remains on and it does not appear that the system recognizes the external drive. The red light remains steady...I don't thhink the drive is running. How...
it is a known issue that these particular drives sometimes don't get recognized by the Operating System, after coming out of Sleep, Stand By, or Hibernation.
Simply try to disconnect and reconnect the drive again in the USB port, if this doesn't work then, Disconnect it from the USB and connect it to the Firewire. if this doesn't work then, Restart the computer.
It should solve the problem.
May 21, 2011 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
Acomdata 250 external (SATA) hard drive not showing up on desktop
be safe
go on line to acomdata web site and down load the driver from there
Oct 11, 2017 | Acomdata (HD250SE5-72-PCI) (HD250SE572PCI)...
The red light is staying on on my Acomdata 1TB Puredrive USB Esata 1 TB Hard Drive and the computer will not recognize it.
I would say take the drive out and if you have SATA connectors on your motherboard, connect it directly to you computer and see if the computer will recognize it.  If it does, your enclosure is bad.
Mar 04, 2009 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
Blinking lights and not recognized by computer
Try to remove the internal drive from enclosure and connect directly to PC. Does it show up this way?
Does it make any new clicking/knocking/whirring/grinding sounds like any of these: http://datacent.com/hard_drive_sounds.php ?
Nov 04, 2008 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
Acomdata External Hard Drive blue light constantly blinking and not recognized by computer
how do I fix my external hard drive, because one day I turned it on and the drive was fine, the next day when I turned it on, it kept on flashing blue, does that mean that the drive is dead. Please help me with this.
Aug 04, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Acomdata drive not recognized
the drive may have failed..... they can often be "fixed" long enough to retrieve data. i make alot of money from failed maxtor hard drives.
Robert
Jul 12, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Acomdata no longer recognized
Check your USB Cable connected possible lost contact problem or the power supply of your optical drive.
Hope this will be helpful to you.
Oct 25, 2007 | Acomdata E5 (HD080FE5-72) 80 GB FireWire...
Won't Connect
Well you'll need to be more specific! Does the PC at least pick up the device? Does it come up when you plug it in? Is it in the safely remove hardware list? (Left click on the green arrow by the system clock) Does it show in device manager? Is it a new drive or have you used it before? There could be several reason why the drive is not coming up! regards, babb
May 04, 2007 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Acomdata (HD320UFAPE5-72) (HD320UFAPE572) 320 GB Hard Drive Logo
432 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
terminalcon
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
