Question about Brother IntelliFax-2820 Laser Fax
Paper keeps getting stuck in the cartridge itself
  • 46 Answers
Bit of paper stuch under toner cartridge, or fuser drive problem, also poor toner cartridges can contaminate charger unit and wear drum causing arcing
Posted on Jun 11, 2009
I keep getting an error message about a paper jam for my printer but there is absolutely no paper jammed anywhere in the machine.
Have you tried a new toner cartridge, The toner cartridge has moving parts, and of the cartridge gets stuck, the printer may indicate a paper jam.
Also paper often tears when clearing jams, and the little shreds of paper can stay in the rollers of the printer and keep it jammed. Make sure to inspect all the rollers to make sure they move freely, and do not have anything stuck in them.
Aug 21, 2014 | D-Link D LINK DELL B1260DN MONO LASER...
My paper keep getting jam and will not go into print
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persists and you see no paper that is stuck in the printer it
May 14, 2011 | Office Equipment & Supplies
Error code 6A00 shut down machine. How do you fix it?
The Problem Canon PIXMA MP800 Error 6A00
1. The print head cartridge keeps locking itself up on the right hand side.
2. Frequent 5100 errors even when the printer is on standby
3. Even when I wipe up the print cartridge, the next print will
mess up the bottom of the print cartridge with ink again.
Step for troubleshooting canon pixma MP800
1. Opening the cover and wait for ink carriage to center
2. Pull out power cord
3. Pushed carriage to far left (should slide easily)
4. Used paper towel and wiped purge unit a lot of times
(press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Used diluted napisan (oxygen-based cleaning agent in the
ratio of 1:3 with powder:water) and soaked paper towel
6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white.
7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down
8. Slided carriage back to original position
9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Oct 26, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Screen says cartridge cradle is stuck but it moves freely
Ok there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 05, 2010 | HP PhotoSmart 7760 InkJet Printer
Paper jam message no paper jam cartridge gets stuck HP 6310 all in one
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 11, 2010 | HP Officejet 6310 All-In-One InkJet...
Lights are flashing on printer and it will not print . the voice says there is a problem with the printer. I did the alignment process but the voice keeps saying there is a problem. I took both cartridges...
There 3 light on the printer that able to indicate to user when problem occur. Which is the light u mean here?
1st button light blink rapidly = the printer may be out of paper, so load more paper and press the 1st button itself to continue. Or may be paper jam is occur, so clear the paper jam and press the 1st button light itself to continue.
If 1st button light blink slowly = mean the cartridge carriers are stuck, so raise the scanner unit and remove any object blocking the path of the cartridge carrier, make sure the cartridge are closed and installed properly, then lift the scanner unit, gently push the scanner support towards the cartridge carriers, and carefully lower the scanner unit until it is completely closed. After that press the 1st button itself to continue.
If 2nd LED light blinking = the color cartridge need to be replaced soon.
If 2nd LED light is ON = the color cartridge need to be replaced immediately.
If 3rd LED light blinking = the black cartridge need to be replaced soon.
If 3rd LED light is ON = the black cartridge need to be replaced immediately.
YBC (/\)
Sep 28, 2009 | Lexmark X2500 All-In-One Printer
The amber lights are blinking next to the printer icons and exclamation points on top of the printer. How do i get that to stop so my print job can go through?
YBC (/\)
Aug 06, 2009 | Lexmark X2500 All-In-One Printer
Paper gets stuck, eject indicator keeps blinking with out any effect on pressing it
its the problem in the main board of the printer that has shorted out the new colour and black cartridge in your printer which you installed.or may be one out of them.it happens some time.so you will have replace the cartridges 1 by 1 with new cartridge and check out.if still the problem then replace the board.that costs $12 plus shipping. mostly the cartridges have shorted out and replacing the cartridges will solve.
May 08, 2009 | HP DeskJet 610c InkJet Printer
Brother IntelliFax-2820 Laser Fax Logo
63 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
