Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Boot up Problem
I had installed windows on drive d and then formatted drive c and then again re  installed it on c. i got a dialog for booting up from two drives so i deleted the copy of windows on drive D but still i am gtting the same dialog . how do i remove it?
    Problem Solver:
  • 6 Answers
Maybe updating the BIOS would help just try it!
Posted on Oct 24, 2007
Bootmgr is compressed
The Windows operating system allows you to compress the files on your drive to conserve disk space.
In some situations, this compression process will compress files required for the operating system to boot.
Files that are compressed must be decompressed prior to execution.
Since the operating system has not loaded, boot files cannot yet be decompressed.
In this case, the operating system will fail to load and a "BootMgr is compressed" message will appear.
An easy way around this problem is to boot from the Windows DVD, and use the provided interface to access your drive properties and decompress it.
Turn on the computer, and insert your Windows DVD.
Press a random key on your keyboard once you see the "Press any key..." message.
This interrupts booting from the hard drive and forces a boot from the Windows DVD.
Click the "Next" button at the bottom of the Windows 7 dialog, and then click the "Repair your Computer" link Below.
http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7
http://msdn.microsoft.com/en-us/library/aa364219(v=vs.85).aspx
File Compression and Decompression
Select the "Load Drivers" button at the bottom of the "System Recovery Options" dialog, and click the "OK" button on the "Add Drivers" dialog.
This opens a file browser on your screen.
Click the "Computer" icon, which is located on the left hand side of the screen.
This displays an icon for your disk drive.
Right-click your hard drive, and click "Properties.
" This opens a Local Disk Properties dialog.
Click to deselect the "Compress this drive..." option at the bottom, and then click the "Apply" button.
Select the "X" icon to close the file browser window.
This takes you back to the Install Windows dialog.
Press the "X" icon at the corner of the Install Windows dialog.
This opens a cancellation dialog. Select the "Yes" button on this dialog to restart your computer.
Nov 26, 2013 | Acer Extensa 5620 Notebook PC
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
My bios setup is locked with password and i dont know the password,what shall i do?
The Windows operating system allows you to compress the files on your drive to conserve disk space. In some situations, this compression process will compress files required for the operating system to boot. Files that are compressed must be decompressed prior to execution. Since the operating system has not loaded, boot files cannot yet be decompressed. In this case, the operating system will fail to load and a "BootMgr is compressed" message will appear. An easy way around this problem is to boot from the Windows DVD, and use the provided interface to access your drive properties and decompress it.
Turn on the computer, and insert your Windows DVD. Press a random key on your keyboard once you see the "Press any key..." message. This interrupts booting from the hard drive and forces a boot from the Windows DVD. Click the "Next" button at the bottom of the Windows 7 dialog, and then click the "Repair your Computer" link Below. http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7 http://msdn.microsoft.com/en-us/library/aa364219(v=vs.85).aspx File Compression and Decompression Select the "Load Drivers" button at the bottom of the "System Recovery Options" dialog, and click the "OK" button on the "Add Drivers" dialog. This opens a file browser on your screen. Click the "Computer" icon, which is located on the left hand side of the screen. This displays an icon for your disk drive. Right-click your hard drive, and click "Properties. " This opens a Local Disk Properties dialog. Click to deselect the "Compress this drive..." option at the bottom, and then click the "Apply" button. Select the "X" icon to close the file browser window. This takes you back to the Install Windows dialog. Press the "X" icon at the corner of the Install Windows dialog. This opens a cancellation dialog. Select the "Yes" button on this dialog to restart your computer. Hope this helps
b>
Jan 21, 2013 | MSI Wind U100-016US Laptop
b>
Jan 09, 2013 | Microsoft Windows 7 Ultimate 32bit
Can not boot from Win XP Pro without an auto restart
Hi Jeff,
I see you are having issue installing windows, getting an error the the Boot Manager is missing...
The windows Disc that you have is this a burnt copy? possible that the installation files on the Windows you have is incomplete.
But if I may ask before you tried installing this Windows what windows did you have on your computer?
Have you tried booting the disc directly from the CD drive instead of installing it from within windows.
Go into BIOS and change the boot configuration of you Computer make sure the the CD/DVD drive is selected as the primary boot option before the hard drive, once that is done restart your computer make sure that you Windows disc is in the cd/dvd drive, you should get a prompt on the upper left saying to boot from cd press any key - press Enter right away once you see that prompt this should boot from the disc for the installation to continue but if still it looks for the Boot Manager the copy of your installation disc maybe incomplete.
Also you can try to wipe clean you hard drive and try again again with the installation.
Jul 30, 2012 | Microsoft Windows XP Professional
Hard drive full running xp ,drive is paritionedc,d
To delete a partiition is quite easy in windows. but you will need a third party application like "partition magic" to merge two partitions together, this could be costly
The best advice I could give you is to back up all your information and reinstall your windows straight onto one partition. This will improve your overall speed and also probly also free more space by deleting unwanted programs, spam etc.
Regards
Dec 05, 2009 | Dell Dimension E310 PC Desktop
Soyo sy-p4vgm motherboard unable to access BIOS setup menu
Offcourse! first of all insert CD into CD ROM then boot from cd. Select your CD drive like d: or e: or f: etc and then press enter. Now give a commond format c:/u/v and press enter. After the formating drive you can install windows 98 so now reboot your system again. Then boot from CD once again and choose your drive and install windows.
2nd way, If everything could not be possible then you should boot from CD again then select your CD drive and type a command fdisk and press y or enter 2 times. Now you choose 4 number and press enter and check the drive format if it is not FAT32 its mean that you should press 3 and then press 4 and now press enter then press escape. Then press three button at a time Ctrl+Alt+Del now your system will reboot now once again Boot from CD and choose CD drive and type fdisk and choose 1 then choose1 and now press enter and once again press three button at a time Ctrl+Alt+Del now your system will reboot. Once again boot from CD and select your CD drive and now you can install windows 98 now insert CD into CD ROM then boot from cd. Select your CD drive like d: or e: or f: etc and then press enter. Now give a commond format c:/u/v and press enter. After the formating drive you can install windows 98 so now reboot your system again. Then boot from CD once again and choose your drive and install windows.
Thank You
Jul 30, 2009 | Soyo SY-P4VGM Motherboard
My laptop wont boot up
Hi, a Pc wont boot up beacuse of certain reasons i the Ram are bad or seated badly so pls look on them .
2, your harddisk is corrupted operating system cant start .
Now get operating system cd then try booting with it .
Jul 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
I want to install again the WINDOWS 2000 Professional and i can't do it because it shows a blue image and says that i've to put the win 2000 pro disk on the diskdrive and i put. when i go to the...
What is the boot order in the BIOS? Set that to 1=FDD 2=CD-ROM 3=HDD
While the PC is still on, put the Windows CD in the drive
Restart the PC, watch the screen for a prompt to boot from cd - press a key
The installation will start, you will need to choose where to install Windows
If you do not need to save any data, format the C: drive and install window there.
Follow the prompts the rest of the way through the installation.
You will need to enter the Windows License code at some point.
It is a good idea to change the regional settings to match your location and how you want the date and time formatted.
Most things should be detected and installed automatically, so you are safe to accept the defaults.
After about 45 minutes you will need to restart the PC and then you should be ready to enjoy Windows 2000.
Be sure to go to Windows Update and install all of the patches.
Good Luck and let me know how it goes.
~ Spoem
Mar 24, 2009 | Toshiba Portege 3110CT Notebook
I have 2 drives C:\ and D:\ Im trying to reinstall my windows but my c drive would not allow me to do so. Instead I could only do so on D:\ Now I have three options during bootup: c:\Windows, D:\Windows...
Hi.
Insert the xp CD in the drive.
Where it asks you to choose a location to install xp, just delete both the partition. (default button D)
Then make two fresh partition and install xp in the first one (that is C).
This will solve your problem.
Regards
Faraz
Oct 14, 2008 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
16 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
