Question about Pool & Spa
Gatsby ps1 code
Keep getting ps1 code, cleaned filters, replaced pressure switch, no change
5 Suggested Answers
  • 1129 Answers
SOURCE: Honda s2000, 2001 loose of
Sounds like an ignition component failure check for proper resistance through primary and secondary ignition coil windings, refer to service repair manual for exact specs, also the ignitor magnetic pick up may be not up to snuff, the only other ignition component to replace or check is the ignition module and/or plug wires themselves, sometimes when extreme demand is put on the ignition system the plug wires must be high quality and completely isolated from one another. Spark plug wires when routing cannot come in contact with one another in the slightest proximity.
Posted on Aug 23, 2009
SOURCE: po171 code keeps coming up,
did you check the o2 sensor bank 1 ? cause de p0171 code say sistem too lean bank 1 do you need replace this sensor and get a better fuel saving . or maybe is disconected or the o2 sensor wires could by cut o burn, i think about you problem is not the fuel sistem . clean again carefully the maf sensor without broke the tiny couple wires thks
Posted on Aug 07, 2010
  • 6 Answers
SOURCE: We have a Dyna-go turbo
jikapp, sounds like your rotor air ump may be getting worn down. TSC used to carry the replacement kit for it last time I was looking they didnt have one. You have to take the back cover off (the plastic that holds the filters) then remove the back cover. Oval aluminum about six-eight screws. You will see a black round disc with four fins in it. Pull it off of the shaft. loosen the screws holding the backcover to the motor. (You will need to set your clearance for the new rotor.) Install new rotor just as the reverse of removing the old one. Use a .005 feeler guage and roll it just along the top of the rotor and push the aluminum housing down to hold the feeler guage . Tighten surounding screws and re assemble.
Posted on Oct 26, 2011
SOURCE: f 35 code suds changed pressure switch and hose to
Most likely the CCU. Its best to run it thru a diagnostics check to be sure. Some steam models can have a bad steam board that will give the F35 code. That can also be checked by following the diagnostics information which is found in the lower section of unit usually in a plastic bag stuck to the right hand inner side panel.
Posted on Oct 31, 2013
Can you help me figure out why my spa stopped heating?
Without more diagnostic info or what you may have done in your troubleshoot, or what is or isn't happening...
Try cleaning your filter!
Most common reason a spa stops heating!
May 16, 2015 | Optimus Vertical Heater, Gatsby/blue...
My 1995 Camaro 3.8 start right up and immediatelly dies.
dont keep changin parts til u hav solution--a data stream done w factory gear will pinpoint answer-done at private shops----check distributer cap for corrosion-take it off n look inside-replace or clean-also inspect plug wires-they go bad internally----ur residual fuel pressure may be bad-car should hold this when off-there is a test-----check the ground on the fuel pump-its a common issue-------make sure batt-alternator-wiring is okay
Oct 21, 2014 | 1995 Chevrolet Camaro
I have changed out everthing for the F02 code , what will the pressure switch do for me?
The pressure switch controls the amount of water going into the drum Thus switching off the water fill valves .Sometimes the Pressure tube feeding this gets a hole in it in which case machine overfills/ floods.
Mar 12, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Code 1 on a goodman furnace. Changed filter, reset thermostat, hit the breaker for reset and still the temp is dropping and the unit is not kicking from the thermostat. Thermostat is only a year old.
You unit is under locked out mode due fail on start up. Get sand paper clean out the flame sensor, and jump the 2 wires that go to the pressure switch as soon as the inducer came on. Doing this the flame should stay on until it meet set temp at thermostat . If it does what said your pressure switch need replacement . Good luck and keep me up to date .
Feb 02, 2014 | Goodman Heating & Cooling
Lay z spa pump has E02 code which is water flow problem,have changed filter.flushed through ,set reset button but fault code still appears.
If this is an outdoor spa near trees, its almost a guarantee that the impeller is blocked with debris (pine needles can cause this in a hurry)
If the impeller is clean of debris and this is still happening, replace you pressure/flow switch.
Apr 27, 2011 | Pool & Spa
The only way i am able to keep the furnace going for about 20 min or so is by removing the hose before the pressure switch and then squeezing the end of the hose together then replace back onto the...
If there are any condensate hoses, make sure they are free of any blockage as well as the hoses to the pressure switch. Check for cracks in small hoses going to pressure switch. If this has two pipes for venting, make sure both are free of any obstructions. If you can remove them for testing this may help diagnose if there is a blockage. Check air filter and replace. Check the exhaust blower for any blockage within the fan. Sounds like the fan is unable to get the pressure switch to close.
Jan 18, 2011 | Heating & Cooling
Pilot is not trying to light on my carrier comfort 80 (electric pilot). I was getting a error code of 13 that has cleared but now have an error code of 33. I have tried turning the unit off by using the...
13 is a pressure switch error code. Check the venting for any blockage of snow, ice or debris. Make sure the air filter is clean. Check the condensate hose and drain and pump if you have one. Check the pressure switch to make sure there is no moisture in it and the hoses are clear. Look into the inducer fan assembly for debris. You can test the pressure switch by hooking up a jumper to one terminal of the switch and keep the wire connected to it. After the inducer fan gets up to speed, take the other end of the jumper and connect it to the other terminal of the switch still keeping the wire on it connected. If it fires up, replace the pressure switch.
Jan 17, 2011 | Heating & Cooling
Po171 code keeps coming up, I changed the fuel filter. Pressure at fuel filter is 45, pressure at fuel rail is 45. Pressure is 50 with pressure relief valve disabled. Diaphram is good at pressure...
Aug 07, 2010 | Ford F-250 Cars & Trucks
Hayward H250K gas pool heater error code
Low Flow errors are not necessarily real. They can be caused by improper adjustment or a defect of the pressure switch. Locate the pressure switch. Verify that the "switch" makes contact. Adjust the dial, reducing the distance the switch has to travel to engage. This will effectively lower the operating pressure required to operate. Keep adjusting until the unit stays on.
May 27, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Pool & Spa Logo
44 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
