Question about Toshiba Satellite A105-S4334 Notebook
I have a toshiba a105-s4334 and it is stuck in "windows starting up" and seems warmer than usual
  • Jimmy Howells
    Jimmy Howells May 11, 2010
    I need to know if the fan is running properly, and if there is dust built up in any of the vents. Thanks, nightcloak74
Where are the headphone jacks on the Toshiba satellite A105-S4334 laptop loc
There are two ports, a headphone port (out) and a microphone port (in). They are located on the front of the laptop as shown in the picture below. You can check out the tour for the location of all ports at the link below:
http://support.toshiba.com/support/staticContentDetail?contentId=1250686&isFromTOCLink=false
Mar 05, 2015 | Toshiba Satellite Computers & Internet
Toshiba satellite a105-s4334 horizontal lines screen
Possible screen issues. Try an external display to prove the GPU.
Feb 28, 2015 | Toshiba Satellite A105-S4334 Notebook
Toshiba Satellite A105-S4334 PC Notebook Pink Screen and Greek Seeming Letters
Sounds like you have some hardcore malware. You might need to do a system reformat. When you turn on your laptop if you turn on your computer and all you see is this, the hardware could be damaged which would be an odd case. But I'll stick with my first thought. You need that cleaned up.
Feb 22, 2013 | Toshiba Satellite A105-S4334 Notebook
Presciso dos drivers para notbook toshiba satellite a105 - s4334 win xp por favor podem me ajudar?
If you were to log on to the toshiba.com web site, I think you will be pleasantly surprised as usually one is able to download if available, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, Driver downloads and Installation Instructions as required.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
There are no XP drivers to be found with Microsoft as that OS is no longer supported.
I hope this helps.
Jan 26, 2011 | Toshiba Satellite A105-S4334 Notebook
Where is the memory located in a Toshiba Satellite A105-S4334 laptop?
Hi
The memory is normally located underneath the laptop
normally a oblong cover with 2 screws
just undo the screws and remove the plastic plate
Jan 19, 2011 | Toshiba Satellite A105-S4334 Notebook
Toshiba A105 - S4334 laptop,imediately on startup the screen goes so dark I can't see anything but a shadow of the screen,if I clsoe lid and open again I can see the display but only for a few seconds.Is...
Hello wall flower hi, when you turn on the laptop, did you see the start up screen clearly? can you read words on the screen, and then it goes dark? If this is the case, check first the Fn key with the corresponding display for projector, (usually Fn+F5) this combination key is used to display the content of your computer to the LCD or Projector, IF not such a case, it may be problems with your laptop inverter board that powers the backlight. Check your bios settings also.
Feb 12, 2010 | Toshiba Satellite A105-S4334 Notebook
Intermitently, my screen goes dark, but the
1.)It could be your video card
2.) Yes it is expensive for a laptop
3.)I would first check your screen setting for turning off display...
If you are using vista:
-Right click on your desktop then choose personalize
-Then click screensaver
-On bottom click on "change power settings..."
- On the left click on "choose when to turn off the display"
Your monitor can turn off without your computer being in sleep mode.
Dec 26, 2009 | Toshiba Satellite A105-S4334 Notebook
I have a Intel® Core? 2 Duo Processor T5200 in my Toshiba satellite a105 s4334 notebook. what can I upgrade to? the chipset is a 945GM from intel and the fsb is 533, L2 cache of 2MB. please help I...
Go to this page:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1484712&rpn=PSAA8U&modelFilter=A105-S4334&selCategory=3&selFamily=1073768663
From there click on gthe detailed specs and it will show you the upgrades you can do.
Aug 06, 2009 | Toshiba Satellite A105-S4334 Notebook
Toshiba Satellite A105-S4334 Notebook Logo
60 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
