Question about Samsung HLP5085W 50" Rear Projection HDTV-Ready Television
Sound but no picture
Recently my picture went completly, but I still had sound. Contacted Samsung but no help at all - out of warrenty! Still - I ordered another bulb. In the meantime I switched the TV on and got both sound & a picture for most of the day. In the evening the picture simply went. Replaced the bulb - still no picture so bulb problem ruled out.
Any ideas - I've cleaned up any dust I could find.
  • hcamper Nov 07, 2007
    Besides having no picture but do have sound when I try to turn the TV off with the remote or front panel nothing happens and I have to unplug from the wall. This same thing happened after I replaced the bulb and after a while the notice the bulb is bad comes on. I was told by Samsung to call around to find someone to repair it. Please help before I take a bat to it.
  • leegeezer Dec 31, 2007
    i have same problem picture would turn off but still had sound. checked the bulb was still working it was then thought it might be overheating problem. so i took off back panel and gave it a clean up but same thing kept happening so i took back panel off again but left it off to get more air into it. i had to blu tak cut off switch in place. this seemed to solve problem but after about 6 hours running it went again had to switch off with the remote wait 2 mins turn it back on i still have problem but lasts much longer before the pictures turns off again. i can see fan turns but wondering if its turning fast enough to get right amount of air flow.
  • 105 Answers
There are several things that need to take place for the lamp to turn on. first the color wheel needs to turn on ( if you can hear a whinning noise then this is fine) next the tv will send a signal to the lamp ballast to turn on, and the ballast needs the 130v dc supply from the power board ( simoly remove the lamp and reinstall the lamp door, turn tv on, and if you hear an arcing noise from the ballast you know this is fine too. the board that controls all of this is the dmd board. so if the color wheel works, ballast starts then i would replace the dmd board....
Posted on Oct 24, 2007
  • Troy Shull
    Troy Shull Oct 24, 2007
    i forgot that samsung has had issues with the lamp door switch. simply solder all three pins together on the switch to bypass this function. try this before the above comment
I have the same problem. It started once or twice a day then more and more More likely DMD board overheats and develops a contact or thermal protection issue shuting down the picture projection.Replacind the lamp or color wheel will not help . For that you will have a error code blinking at the front power button. This problem gives no error code ,picture just dissapears while you still can see the light working if you just look at the back of the tv.and will have sound.You can replace the board ,easy to do but the new board is expensive ,around $ 500 or put a small fan from the outside blowing inside.The best is a small square shape the one you can remove from computers and just hang to the left side of the grill to blow in air, Do not try to blow in air by the lamp door!,that's an exaust area for the lamp fan!.Keeping cooler the tv will not shut down the picture that often That's how I did .I Paid $ 2500 for tis Samsung HL-r 5067w,replaced the wheel and lamp ,with no results,,next will be to replace the whole tv as with $900 can get a new one that will be anything but Samsung DLP,why would spend other $500 for DMD board? to last an other 2.5 years? The whole tv is a technical screw up Samsung knows that the light bulb overheats the tv's light engine creating expansion,contact ,ect problems,,inside fans are not big enough to handle the heat,bigger fans would be too loud, that's why come out with LED light projector,no heat there,but I had enough of Samsung
Posted on Dec 19, 2008
I currently experience the same problem as described above, can someone validate if the above method work or how u end up fixing it at the end???
Posted on May 09, 2008
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Sound but no picture is it the picture tube or just another problem
most likely will not be the tubes mate, if the tubes go then you just get a big mix of red green and blue colours in the screen - sound but no picture is more likely to be the starter unit on the flat screen.
flat screens have a starter unit - mine went on a samsung but under warrenty
Sep 08, 2009 | Sony KP-53HS20 TV
Tv plays sound but no picture or any signs of backlight
This sound is a capcitor pop and this could be in the power supply unit itself. The glass could be a fuse that took the brunt from the capcitor pop.
1. Unplug the unit and do not plug it in.
2. if its under warrenty take it in please!
3. if its not under warrenty and you know eletronics verify what cap popped and replace that and the fuse.
4. if you do not know about eletronics this work would cost you around $150 for the wrok done.
Good luck I hope this information helps you!!
Jul 17, 2009 | Vizio L32 32 in. LCD HDTV
Sound went out
Please help ! I moved my Samsung hcn4226w and reconnected. The picture is fine but, no sound now and cannot use all functions on the remote. Any suggestions would be great. Thanks.
Jun 29, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsong 37 " lcd no display only sound
I think it the main logic board!! I have 42 plasma samsung doing the same! change that works!! cost $124~~
Mar 23, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung HLP5085W 50" Rear Projection HDTV-Ready Television Logo
474 people viewed this question
Jerry Greenberg
Jerry Greenberg
