Question about Jl Audio E1200 Car Audio Amplifier
I have a jl 500/1v2 and when i have the volume up for some time it teens to turn the amber color light on and turns off my amp and sub i turn down the volume for like 30 sec turn it back up and every thing is fine i cant seem to find out what it is ?
    Problem Solver:
  • 8 Answers
Its probably wires touchin or the ground not connected well with fat enough wire. i would try to rewire and do everything all over again because one wire or fuse is messing up i had t he same probelm. its the red light on the amp is ur amp shut off or ur warning light?
Posted on Jun 04, 2009
JL Audio 1000/1 v2 distortion problem
Make sure all your connections are tight , really tight . Check ground , make sure it's to clean shiney metal. Three subs are going to have a low ohm load if paralleled . These amps are not 1 ohm stable ,if below 1.5 ohm's you will have problems. They need to be series paralleled to raise the ohm load. These amps put out the same power from 4 to 1.5 ohms.
Mar 14, 2012 | Jl Audio Car Audio & Video
Amp goes into protection mode when i turn up volume
Sounds like you are running your subs at to low of ohm. Amps are rated differently on the levels of ohms or resistance that they can get to. If you have a dual 4ohm sub and run it in pairrell it will drop to 2ohm and if you run the same sub in series it will be 8ohm. Your amp will go into protection if the ohm is to low.
-david
Nov 07, 2010 | Jl Audio 12W6 Car Subwoofer
My power pyramid sub is smoking i think its the jl 1000/1
If the sub is new, they need to be broken in.
All sub woofers need a break in period of about 5 to 6 hours at medium volume.
The reason is because the glue needs to be cured. This is done by the heat from working.
If you are giving it too much volume too soon, you are burning the glue.
Back off the subs and only play them at medium volume for about a week.
Nov 22, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
Apr 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Jl audio 500/1 amp low ohm light at high volume
I would try running the subs in parallel. Pos to Pos Dual Voice, Neg to Neg Dual Voice. Then Run + to + stereo - to - stereo on both channels.
So you have + and - running to one channel and + and - running to the other channel.
Also your LPF filter could be set too high.
Feb 07, 2009 | Jl Audio 500/1 Car Audio Amplifier
JL 300/2 v2 Power Light Blinks, No sound out of Sub. Works in friends Car HELP
Are you sure you don't have any shorted wiring or defective speakers?
Sep 30, 2008 | Jl Audio 300/2 Car Audio Amplifier
Jl amp
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead to the B+ terminal of the amp. If the voltage drops below ~11 volts, you need to check the wiring for the B+ line to see where you're losing voltage..
You need to do this as the amp shuts down. Connect the meter and watch the voltage as someone increases the volume.
Dec 31, 2007 | Jl Audio 250/1 Car Audio Amplifier
Jl amp
the overload protector of your unit it so sinsitive try to cutof the overload relay and then observe 20 min. monitor the allominum heatsink the temp. normal
Aug 27, 2007 | Jl Audio 250/1 Car Audio Amplifier
Car amp's stopped working. Putting out a heart beat sound through subs but no bass.
could be low current ,disconnect all power including ground for 20min N.B most amps will seem to be shorted at output but this is normal due to damping ratio.
Jun 11, 2007 | Jl Audio E1200 Car Audio Amplifier
Jl Audio E1200 Car Audio Amplifier Logo
155 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
