Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
Tv doesn`t start
Samsung lnt4042hx/xxa lcd.at some point i had to wait like 20-30 minutes till it start.it makes a cycling noise in the back problably from the capacitors in the back. thank you?
  • 927 Answers
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts. The board on left, you will see the cap tops are swollen.
Thanks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
Will not power on..have to unplug wait till red power light goes off then plug back in ..then will power on fine
Power cycle your TV by unplugging it and leaving it for a few minutes. Plug it back in and turn it on. Restore settings back to factory defaults. If everything else fails, then I would recommend pursuing repairs.
Oct 18, 2013 | Dynex DX-LCD32-09 LCD TV
My Samsung model HLR4667WX/XXA is making the same buzzing noise I've read about by googling the model + buzzing noise. I need someone in Phoenix that can replace the color wheel or so it seems. Please...
It is easy; just look for a video on you tube and with a screwdriver and some care you can fix replace the color wheel yourself.
I replaced mine in fifteen minutes. Note, I had to replace my ballast prior to this so I had a little experience.
Good luck.
Feb 23, 2011 | Samsung DLP HL-P5663W 56" TV
Samsung LCD 650 tv . Problem is that when using remote to turn on is appears to cycle on and off repeatedly making that annoying samsung noise. Nothing appears on screen. Unplug it and wait a few minutes,...
The tv power supply board is the problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 28, 2010 | Televison & Video
46" LCD Samsung TV Model# LN-S4692D I have no picture
The back light inverter board may have gone out or it is not getting the 24vdc from the power supply module. Start checking for voltage feeding the inverter board.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Samsung+LN-S4692D+
Jan 07, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LNT4042HX HD Television
the power supply board needs to be replaced, VERY common problem.
Nov 11, 2009 | Televison & Video
Samsung 50" HD DLP TV video goes out
Common problem of a bad lamp call your local repair shop on price and availability of lamp.
Oct 22, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung LCD TV slow to start
Dont have a solution, my samsung 46 inch is doing same thing. Have you found a solution?
Oct 05, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Samsung lnt4042hx/xaa 40in lcd tv wont turn on
I concur with Lightnbaby.... had same problem... my TV LNT4042HX/XAA took 10 min to start sometimes... the capacitors on the power supply board had bubbles on top 4 of them all 10/1000Uf. Samsung wanted to charge $220+ to have a guy come out and fix. J&J parts (samsung vendor) wanted $108 for a new board. I replaced the 4 capacitors for $4.68 and the TV works fine now!!!!!
Apr 14, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
330 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
