Question about Sharp EL-738 Scientific Calculator
The calculator is intermittent: Most of the time
The calculator is intermittent: Most of the time the display is erratic (half of the LCD display turns on and it is imposible to even enter a number on the key pad). Sometimes, with no batteries in the calculator and with a strong light source, it works normally for a short time then it tilts again (erratic display).
Marcel (marcelpigeon@hotmail.com)
Calculator model no. EL-546L made by Sharp
Not knowing what to do, I tried anything that could possibly help:
I installed fresh batteries and I pushed the reset button on the back of the calculator (Sharp EL-546L) and finally, it work all right after more than 5 years I own the calculator and where it did work correctly for 5 minutes. I tried the reset button in the past (long time ago) and it didn't work. This time it worked because, maybe, I've used fresh batteries.
Marcello
Posted on Jun 05, 2009
The display on the front panel is working erratically
some times the wire at the bottom of the door will break partial and intermittently open and close
Apr 27, 2017 | Refrigerators
Code 15 on 1988 ram 150 without vehicle speed sensor
Code 15 relates to a failure in the vehicle speed sensor circuit. The job of the vehicle speed sensor is to inform the computer about the speed of the vehicle so the computer can calculate engine load and prepare the engine idle speed control system while the vehicle is decelerating. On deceleration, the idle speed control system will allow additional air flow into the engine as the vehicle rolls to a stop. Usually code 15 will be accompanied by erratic speedometer readings (or no reading), erratic AT gear shifting, TCC lockup clutch instability, and intermittent or complete failure of the cruise control.
Oct 21, 2013 | 1999 Dodge Ram
Why does the lcd display goes bad
Faulty electronics. It may be time to look for another calculator. Try pressing the 8 key enough times to fill the LCD 88888888888. If
Apr 03, 2012 | Sharp EL-512H Calculator
Screen does not display complete numbers
Half of the display is only working, the problem is in the driver ic that drives the display, it is simply not cost effective to repair the item, further ahead to replace the calculator.
Mar 06, 2012 | Texas Instruments TI-30X-IISTK Scientific...
I just filled up my tank and now the light is on and the tank shows empty?
{: ) Your fuel level sensor could be intermittently reading high resistance and may need replacement. An intermittent reading can happen at any level (say 1/4, 1/2, 3/4) and will suddenly give you an empty reading and fuel light, sometimes an SES light may follow. At any rate, this kind of symptoms still recommends replacement of the fuel level sensor.
You can observe it by yourself. Does it read normal on lets say half full but will read empty when you can calculate that you still have 1/4 remaining on your tank. In your case you've just filled it full, and it's no different once the fuel level sensor start getting erratic readings.
Although it may take time, you can wait until the fuel level stabilizes to a certain lower level where you think your gauge was reading normally before. You can also do some stop and go, forward and reverse, to slosh the level arm to a a more readable position. Check if you can get clearer results out of this trick.
A scan tool is a better tool to determine quickly the condition of the sensor and may tell also if there are other codes that is related to your problem.
Jul 16, 2011 | 2006 Chevrolet Trailblazer
I'm using a TI-83 Plus calculator. Halfway through my screen there is a straight line preventing me from using the top half of the screen. No matter what I do I can only use the bottom half. Is there...
You probably have your calculator set to display the graph on the home screen. Try pressing MODE and going to the last option, then changing it from "Horiz" to "Full". "Horiz" means it is displaying the graph (probably without axes since your screen is otherwise blank) on half the screen.
Jan 27, 2011 | Texas Instruments TI-83 Plus Calculator
My Casio fx-85v Super - fx solar power calculator shows a erratic
Yeah I had the same problem, you need to open your calculator and check if all the screen cables is alright, i had just put sellotape on the back of the screen from inside so that the screen hold better, and it works for me if for you not maybe something broken in the schema but try it. The thing I know for sure the problem is in the screen or from where it get the data the schema. Tell me if it's working
Jul 01, 2009 | Casio FX-115ES Scientific Calculator
My lcd is bad the half is dead
If you want to contact TI Product Support here as the contact details.
Hope it helps.
Jun 18, 2009 | Texas Instruments TI-89 Calculator
Sharp EL-738 Scientific Calculator Logo
397 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
