Question about Acer Aspire One AOA150-1784 Netbook
I ordered a NEW KEYBOARD FOR THE ACER ASPIRE ONE NETBOOK. i NEED TO KNOW HOW TO PUT THE NEW ONE ON. i ALREADY VERY CAREFULLY REMOVED THE OLD ONE.
    Scholar:
  • 52 Answers
Well be sure you have the keyboard connector firmly connected to the board connector. Then it's simply a matter of replacing everything like it was and placing the right screws in the right holes. If you feel some resistance dont force it, you may try to place the wrong screw there and it may damage your laptop. Just take your time and go step by step you should be fine.
Posted on Jun 03, 2009
Hi i have got a new keyboard and wish to change it on acer 7520
taken from http://www.batterycentury.com/acer-aspire-7520g-502g25mi-keyboard-p-152819.html
Acer Aspire 7520G-502G25Mi Keyboard Repair and ReplacementAre you considering laptop keyboard repair? You might think twice if you happen to be the lucky owner of a laptop, because replacing the keyboard rather than repairing it could be a lot less expensive. Laptop keyboard replacement on this particular model is very easy and takes just a few minutes. Here is a quick Acer Aspire 7520G-502G25Mi Keyboard repair tutorial with step-by-step instructions. Once you have purchased the new keyboard, all you need to replace the old with the new is a screwdriver and something plastic, flat and thin like a credit card or guitar pick.
Step one: Remove the two screws from the bottom of the computer that are holding down the Acer Aspire 7520G-502G25Mi Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step two: Turn the computer over, open the cover and insert the credit card or guitar pick between the bezel and the laptop screen. The bezel has pegs that sit in holes, you need to slowly pry up the bezel. It will make a bit of a popping noise as it is removed.
Step three: Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the Acer Aspire 7520G-502G25Mi Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon cable will now be released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire Acer laptop keyboard.
Final step: To insert the new Acer Aspire 7520G-502G25Mi Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the Acer Aspire 7520G-502G25Mi Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
May 16, 2011 | Computers & Internet
ACER ASPIRE ONE NETBOOK need help, keys 5,7,9,-,[ have stopped functioning, possible to small amount of coke being spilled on keyboard, have removed keys to clean under them but doesn't seem to make...
There's a need for you to bring your netbook to a service center to check for any possible hardware problem. Usual cleaning should be able to resolve this issue but if not it requires a local service center to ran further check on your netbook.
Apr 11, 2011 | Acer Aspire One Netbook 8.9" Notebook
My acer aspire one notebook is producing no sound since i changed the original windows
need to run service tag at acer support with old operating system to determine what audio card you have ,unless you already know,then look at other models with that same audio card that are running your new operating system,that driver should fix your problem,hope this helps,aloha from maui todd0708
Nov 13, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One A0A150 keyboard issue,
Sounds to be you just got a faulty keyboard from HongKong, if your old keyboard works except the the Z and the new keyboard works only with function keys, then it sounds to be that the new keyboard is not ment for your laptop. if anything you should of had the same problems as your old keyboard. try using a USB keyboard.
Aug 17, 2009 | Acer Aspire One AOA150-1983 Notebook PC
"lost backspace button on Acer Aspire One"
Unfortunately, there is no way to purchase just one key of the keyboard. Acer does offer full replacement keyboards and they are easy enough to install. Unless you can find just the backspace key on eBay or something, you might have to replace the entire keyboard.
Thanks for using the fixya Forums.
Mar 28, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire one F2 key not working
Check the connector, it may be one row off when you replaced it.
Mar 18, 2009 | Acer Aspire One Netbook 8.9" Notebook
How do I remove the keyboard on my Acer Aspire 1640z?
Ok,
Usually there are hidden screws under the screen.
usualy under some clip or something.
if you find them unscrew the keyboard.
DO NOT YANK IT OUT!
carefully remove the cord .
PLEASE SEND A PHOTO OF THE LAPTOP for further info
Jun 30, 2008 | Acer Aspire 1640Z Notebook
Acer aspire keboard replace ment
What is your question? Do you want to know how to replace the keyboard or where to find a replacement keyboard?
This disassembly guide might help you out: http://www.eserviceinfo.com/download.php?fileid=16546 but the pictures are pretty small. Essentially you need to remove a few screws from the bottom of the laptop which will let you carefully pry the panel above the keyboard up and off. Then you will see the two screws holding the keyboard in place. After you remove them you will see where the data ribbon from the keyboard connects to the motherboard. This can be removed by carefully popping the small plastic tab up; the ribbon will slide right out. The replacement keyboard can be installed via the same method.
You can find replacement keyboards on ebay: http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=aspire+3000+keyboard&category0=
Mar 27, 2008 | Acer Aspire 3000 Notebook
How to instal a laptop dvd rw
open cd rom tray.open laptop lcd screen flat, remove the 2 screens on the back of the hinges.carefully remove the bezel(just above the keyboard, with the power buttons etc )from right to left.remove 2 screws securing keyboard.you will see one screw that holds the cd/dvd rom in place.remove screw,pul on tray carefully, cd rom will slide out. replace with new cd rom.
Dec 07, 2007 | Acer Aspire 5100-5033 Notebook
Acer Aspire One AOA150-1784 Netbook Logo
120 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
