Question about HP iPAQ hw6515 Pocket PC
Gps wont start
I have a diginav gps for my ipaq, the program starts up fine, but it cant locate my position, it did work fine before, tried reloading software but to no avail
  • Anonymous Nov 07, 2007
    I have a Hp Travel Companion iPAQ and recently loaded the Diginav system onto it. It is not able to locate my position. It reads that there is no gps signal and I have tried the configuration, but I can not seem to start up my iPAQ!! Please Help!!!
  • 3 Answers
The ipaq requires a GPRS connection to download and refresh its GPS files every 2 days. Check the GPS symbol at the bottom right corner of the screen. It has to be blue. If it is grey, the GPS files need to be refreshed. Hp recommends MapAsia and it works, though the landmarks are not correct. The roads are ok. I do not know about diginav.
Posted on Nov 15, 2007
How to pair a iPAQ 214 with an external GPS receiver?
It's pretty easy.
In your iPAQ 214 go on SETTINGS > GPS > and make sure the INCOMING CONNECTIONS are on CHANNEL 6, and for the OUTGOING CONNECTIONS are on CHANNEL 5.
Start the external GPS device, start your Bluetooth connection on your iPAQ and you're ready to go.
Mar 06, 2011 | Garmin nuvi 255W GPS Receiver
I cant uploaud waypoints to gpsmap 76csx
Try reloading the software, then load the program, then attach the GPS.... Should start communicating at this point. Make sure the cable is seated correctly....
Feb 14, 2010 | Garmin GPSMAP 76CSx Handheld GPS GPS...
IPAQ 4700 hard resetting on its own.
I also own an ipaq 4700 and experienced the same problem. Even after reloading the OS I continued to have this problem. I did buy it refurbished but I fear this may be a common hardware problem. From my research it would appear the battery is the most likely culprit, I have not tried replacing mine but it may be worth a shot, if nothing else you have an extra battery which means less time at the charger :D
Apr 16, 2009 | HP iPAQ HX4700 Pocket PC
Ipaq 6515 does not locate a gps signal
most probably your Gps module had developed problem.
Jan 03, 2009 | HP iPAQ hw6515 Pocket PC
HP iPAQ Bluetooth GPS, IPAQ has no signal
I noticed now that the 'green lite' on my receiver does not come on at all. I can not find where I can get a replacement receiver
Sep 09, 2008 | HP iPAQ Bluetooth GPS Navigation
HP ipaq with navtec gps software and sd card fails
Ok, nice job Robert,
I'm posting your solution here to remove it from the unsolved problems list.
Solution by Robert:
This problem was finally resolved as a corrupted map file on the SD memory card in the hp ipaq 5550. Solution was to reformat the memory card using fat32 memory format. I used a SD memory card slot on my laptop and right click the drive letter and select format to format the memory card. After that, I reloaded map files to the memory card and all was OK. Note that previously I had loaded map files on the memory card successfully but that was not good enough. A reformat of the memory card was apparently needed.
I had also previously tried a hard full reset of the ipaq by pressing and holding the lower two buttons (calendar and itask) while holding in the reset button with the stylus for 5 seconds and resynced my contacts and reloaded the gps software, but this was to no avail. Try the re-format.
Jun 22, 2008 | HP iPAQ H5550 Pocket PC
Ipaq h5455 wont stop wibrating and i cant reset it
try a hard reset - it will restore to the original state. it removes all files and programs in the memory files in a storage card wont be affected.
Just hold down the calendar and today buttons, these are the two outer buttons on the lower left and lower right, then using a stylus press and hold for at least ten seconds the soft reset button this is located on the lower right edge of the unit. The screen should reset and the iPAQ will boot up again.
Mar 21, 2008 | HP iPAQ H5455 Pocket PC
Hp ipaq hw6915 gps not connecting
down load regedit and make some changes in the register so you will get an ikon GPS make the changes you will find i many forums and it will work
Dec 17, 2006 | HP iPAQ Bluetooth GPS Navigation
GPS...
Do you have sufficient memory on your iPAQ? Check your memory settings, also check running programs tab, maybe you have too many programs still running in the background causing the latency. Try a soft reset (stops all running programs in the background) or end task on them, then see if it still lags.
Sep 08, 2005 | HP iPAQ hw6515 Pocket PC
Ipaq Quick GPS connection file downloads
You may need to use the hard reset to make the quick gps connection working. but you will lost all ur program or data, including smart nav or tom tom. if you ready want to use the hard reset, remember to download smart nav or tomtom program. or you will end out no map in your system. good luck
Sep 07, 2005 | HP iPAQ hw6515 Pocket PC
HP iPAQ hw6515 Pocket PC Logo
139 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
