Question about LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T...
LG refrigerator keeps beeping even with doors closed
My LG Refrigerator Mod. # LFC25760ST started beeping, even with doors firmly shut. I did get it to stop once, and the temp returned to normal, but after opening the freezer, the beeping started again and I haven't been able to stop it. For some reason, even with doors shut, the temp seems warmer, as if the fridge is getting it's commands from the beep warning. Please advise.
  • 363 Answers
SOURCE: LG Fridge door constantly beeping when closed
On the display panel press the right key that turns the door alarm on and off
Posted on Jul 21, 2009
22yooper
  • 828 Answers
SOURCE: LG refrigerator not working
Check and clean the condenser. Unplugging the system allows it to cool off. when you plug it back in it will cool until the heat rebuilds if not rejected through the condenser. Make sure the condenser fan comes on when the compressor runs. A faulty fan motor will cause the same type of problem.
Posted on May 19, 2008
  • 489 Answers
SOURCE: Refrigerator Lights Stayed on, Melted Plastic and Stopped Cooling
The control board relay switch for the light bulb stuck in the on position and needs to be replaced along with the light cover and housing.  There is also a replacement light harness that has a high limit switch to shut off the lights if this happens again.  LG knows about this problem and if you call LG customer service, they will grant a one time warranty extension to take care of this problem.
Posted on Jun 11, 2008
I had the same problem and fixed it by replacing the Main PC board mounted on the rear of of the refirgerator, as rstynls pointed out. Part number is 6871JB1423N, available from Sears parts direct for around $100. I see it's also on eBay for about $80.
Naturally you want to replace any melted parts like the lens shround and cover if needed, but I didn't replace the socket assembly or reflector even the socket assembly was slightly discolored. I don't see how a new socket assembly could incorporate a temperature sensor since that would require there being a wire run for it already in place, unless the original units had the wire there but it just wasn't used. Even so, if you have to rely on the temperature sensor to shut off the light, you have a problem to fix anyway, although in theory it may prevent a fire hazard.
Posted on Dec 09, 2008
SOURCE: BEEPING NOISE
in the back of the fridge there is a panel. Remove the cover plate. Look for the buzzer and remove it. This will cancel the annoying beeping noise.
Posted on May 05, 2009
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Hi, I have a kenmore elite deep chest freezer. Model 253.16582105. can't stop the beeping, even after replacing the 9 volt battery.
Mar 26, 2016 | Kenmore Refrigerators
Fridge & freezer lights and the water display light beep and flash 10-12 times every few hours. Simultaneously a fan motor starts and stops. Any one know what needs to be done to remedy this?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Apr 25, 2015 | Refrigerators
The refrigerator makes 6 beeps after dispensing water. Everything seems to be working normally so I do not understand why it beeps after the paddle returns to its normal position.
Apr 05, 2015 | Refrigerators
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Jul 27, 2014 | Hotpoint Refrigerators
I have an LG LFC25760ST that the door alarm continues to beep even after the door is closed. I do not have the fancy control panel with an on/off button, I only have a temperature control. Any help would...
You have a bad door switch at the top hinge cover. More than likely, a wire has come loose. Can't tell which one since there are 2 of them. You will need to disconnect the wires and check with a ohm meter.
Good luck.
Jul 24, 2011 | LG LFC25760ST 25 Cu. Ft. Panorama French...
How do I remove the lights in the refrigerator section of my LG LFC25760ST? Why would the lights not go off, even with the door closed?
this is not really a solution, but good information. this past Just a class action suit was filed against LG for knowing about the light bulb problem and continuing to sell the fridge.
Oct 15, 2010 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Jul 10, 2009 | LG LFC25760ST 25 Cu. Ft. Panorama French...
LG model LRFC25750WW 25.5 cuft
You may have a problem with the control board and it will need to be replaced.  You will need to have a qualified LG technician to help resolve your issue.
May 11, 2008 | LG LFC25760ST 25 Cu. Ft. Panorama French...
LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T... Logo
2,865 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
